• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Why will this code only trace strings?
Community Beginner ,
Jun 23, 2012 Jun 23, 2012
The following code randomizes the array "doors". It works fine if the array is strings. However,
if I remove the quotation marks, it traces "[object Symbol1_1]" instead.
var doors:Array = [red_button, blue_button,yellow_button];
var randomDoors:Array = new Array(doors.length);
var randomPos:Number = 0;
for (var i:int = 0; i < randomDoors.length; i++)
    randomPos = int(Math.random() * doors.length);
    randomDoors = doors.splice(randomPos, 1)[0];
trace (randomDoors);
Tracing (randomDoors.name) returns the  statement "undefined". How can I trace "doors" without converting the elements to strings?
TOPICS
ActionScript
Views
623
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 23, 2012 Jun 23, 2012
the array class doesn't have a name property.  when you use trace(randomDoors.name), you're asking flash to find the name property of that array.
so, either use:
trace(doors.name);
or create your own function or class to do what you want so you don't have to repeatedly create a for-loop to trace what you want.
Votes
Translate
Translate
Community Expert ,
assuming those doors elements have names, loop through that array and trace each elements name.
Votes
Translate
Translate
Report
Report
Thanks for the reply, but I'm not sure what you mean by that.
I have tried tracing one element at a time with the ".name" appendix and that returns an element of the array without it being in strings.And as I said, if I just put quotation marks around the elements in the "doors" array, then the array works fine.
I'm just a little confused by which array you're talking about and how I should trace it?
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
so, either use:
trace(doors.name);
Votes
Translate
Translate
Report
Report
