CS6 Bridge freeze using Homegroup network
Jun 23, 2012 10:47 PM
Tags: #bridge #freeze #cs6
I installed CS6 Photoshop two days ago and am having problems with Bridge.
I have a network using a Windows Homegroup between my desktop PC (ROB_PC), and a laptop (JUDE_PC) in another room, linked by my broadband router. When both machines are on I can use Bridge to access (read/copy/delete) files on the laptop by clicking on the folder in Bridge - see screen shot below (it's the folder called RAW). I can also, of course, access the laptop files in Windows. If the laptop is shut down and I try to use Bridge, I get a system freeze on Bridge and have to cancel Bridge and restart the laptop to get Bridge going again. It seems to want access to the laptop, even though I'm not looking at any folders on the laptop with Bridge, and the laptop is not switched on.
This morning I can't even load Bridge. Both computers were switched off overnight, but when I switched my PC on and left the laptop off Bridge will not load at all. This happens even when the last used folder in Bridge is NOT the remote laptop, so I can't understand why bridge is still looking for it when it starts. Does it need access to ALL folders on a normal network, even if I haven't requested to look at those folders? That doesn't seem right to me.
Do I need to disconnect from the network?
    Jun 24, 2012 7:58 AM   in reply to rob_ashcroft
    When it comes to networks I know zip.  But from posts I have read what you are experiencing is normal.  Bridge does search for all the pieces and if it can not find them will keep searching.
    If the laptop is off, perhaps if you unplugged the desktop from the network things would work normally.  If unplugged it would not consider the network pieces that it can not find.
    I remember one post not too long ago where a network of many computers the user had problems using Bridge and finally discovered one computer was switched off.
    Hopefully someone with network experience will chime in an give you better advice on what to do.
