Mac Dreamweaver CS6 very slow to open files
Jun 26, 2012 5:25 AM
Hi
My Mac Dreamweaver CS6 opens html files in about 1-2 minutes! It is very very slow. It all works when the file is open but it is the actual opening that is slow.
I have turned off external files but no change.
Any ideas??
Mac Pro
Processor  2 x 2.8 GHz Quad-Core Intel Xeon
Memory  4 GB 800 MHz DDR2 FB-DIMM
Graphics  ATI Radeon HD 2600 XT 256 MB
Software  Mac OS X Lion 10.7.4 (11E53)
    Jun 26, 2012 9:05 AM   in reply to Rob Miller
    Does this occur with all files?
    To test for sure, please create a new document using one of the preset layouts (e.g. 3 column fixed), save the file, quit/restart Dreamweaver, and then try opening that file.
    If it's not happening with the new file, can you share a link to a page you are having this issue with? Or at least the code from the page if it's not yet live?
    Jul 22, 2012 12:50 PM   in reply to Carey Burgess
    I am having the same issues concerning speed. Large take a long time to open or switching between sites. Also when I drag files to the remote server, it sometimes will delete the file or tell me I have a permissons issue. No issues in CS5. This has been a very diappointing upgrade.
    Processor  2 x 2.4 Intel Core I7
    Memory  16GB 1333 MHz DDR3
    Graphics  AMD Radeon HD 6770M 1024 MB
    Aug 8, 2012 10:35 AM   in reply to Rob Miller
    I too have been running into this problem. Would appreciate hearing of any fixes coming up. Also, don't know if it's related, but I've also had a number of spontaneous crashes of DW, always occur just after I've selected a command of some sort in DW.
    DW6 (build 5842)
    Mac OS X 10.7.4
    2.2 GHz Intel Core i7
    8 GB 1333 MHz DDR3
    Aug 15, 2012 12:58 AM   in reply to Rob Miller
    I am having the same problem. The file seems to start to open and the file tab starts to form but then hangs for up to 10minutes. For the first 20 times this happened I would open the file in another program and copy and paste the code in to a new document but this was a little tedious. Now I have learnt you just have to wait and so I go away and make a coffee (or write this comment on the forum) and by the time I get back it is done.
    The only pattern I can see is that they were files that predate CS6 and are .asp.
    Is there going to be an update that fixes this?
    Best wishes,
    Oliver
    Aug 15, 2012 6:48 PM   in reply to OlsVer
    wow, i thought my copy of DW6 was slow taking 5-6 seconds to open files.
    and its taking minutes for you guys. wow.
    Does anyone know of an html editor (other than Dreamweaver) that has autocomplete of user defined css class/id names when editing html? as in, css classnames from a linked or open css file...
    have tried ST2 and Chocolat with no success
    Aug 15, 2012 9:40 PM   in reply to c41
    The speed is still a big issue. I installed the updater for 12.01 and all my issues except speed went away. Today I am having the same put issues as before. It says that it put the files. yet it actually deleted the file on the remote server. Very frustrating
    Aug 15, 2012 10:10 PM   in reply to c41
    Have you tried Microsoft Expression Web 4?  If not then try their trial version and you will be amazed as to how smooth it is and a pleasure to work with.  Color schemes may be not to your liking but pretty good in other ways.
    Unfortunately, it is only for the Windows system AFAIK.
    Aug 27, 2012 2:05 PM   in reply to Rob Miller
    I'm running the 5842 build (ostensibly 12.01), and the first HTML file to open after launch is still ridiculously slow, around 2 minutes. That is just for HTML files, with no associated website. Subsequent HTML files open as quickly as expected.
    Does it really take months to fix this stuff?
    Sep 9, 2012 8:48 AM   in reply to Rob Miller
    This is still a big problem for me. Will Adobe come back to us about this?
    Oct 12, 2012 9:21 AM   in reply to Rob Miller
    Did anyone ever resolve this issue?  I am having the same problem.  Switching between sites and opening files in CS6 takes forever!
    Oct 12, 2012 10:14 AM   in reply to Fergumungus2
    It is just as bad as ever. I thought an update would come along any day but
    it is now getting ridiculous.
    I have stopped taking regular breaks but instead take my breaks when
    Dreamweaver is having a long think. I have had much longer breaks as a
    result.
    I guess it is a delay caused by DW taking a look at the whole site before
    loading a file but I wish It wouldn't. It has caused me quite a lot of
    embarrassment at meetings already.
    Oct 29, 2012 11:36 AM   in reply to OlsVer
    I usually go on breaks too when I open Dreamweaver C6.... another annoying feature is no html tool bars and all the deprecated tags are removed intentionally.... it just so happens there are some sites we manage that do not want us to charge them to change the format of their sites.... almost all the html is missing. there are not even <h1> tags, or <p> tags...didnt know those were deprecated... if you plan on buying this version....keep your CS4 so you can edit older sites....very disappointed in Adobe. They rushed this to market to suck more cash out of your pocket.... incomplete program ...worst one they put out in years.
    Oct 29, 2012 3:18 PM   in reply to LarryRamp
    I have quite the opposite experience.  I have several older sites I maintain in CS6 without any problems.  If <h1> and <p> tags suddenly go missing, I guarantee there's an underlying problem with your code that CS6 is trying to resolve but can't.
    Use the W3C code validator to discover what that might be.
    http://validator.w3.org/
    Nancy O.
    Oct 29, 2012 3:32 PM   in reply to Nancy O.
    The tags are not missing from the page they are missing from the Dreamweaver tool bars... and they are not available to select or add in the favorite/custom toolbar either.
    It is like a scaled down version of CS4 but with some new features...in CS4 there was a text tab that had html tags... the text tab is missing... no html tags... I am using a PC for this application. Maybe Mac works different????
    Oct 29, 2012 4:39 PM   in reply to LarryRamp
    Tags are still in the HTML properties panel, the same as before.  See screenshot.
    Nancy O.
    Oct 29, 2012 4:58 PM   in reply to Nancy O.
    Ok, Good spot for them but when you have the editor in full screen it is nice to use the toolbars on top... the text too bar is gone and you cant add the tags to the favorites tool bar either.see this video to see what I am talking about...
    http://screencast.com/t/eco0N9uN0ZN
    Mar 8, 2013 6:51 AM   in reply to LarryRamp
    This app has a ton of issues. Takes 2-3 mins to open anything with a ton of code. I'm permanently switching to Coda.
    May 3, 2013 6:28 PM   in reply to Rob Miller
    I've been strugling with this issue for  a long time.
    I've found that Dreamweaver takes  about 2 minutes to open  CSS files with @import url for  font face.
    for example:
    @import url(http://fonts.googleapis.com/css?family=Oswald:400,300);
    i've never had problem with  big files but if i place this line into my 20k css file,  it takes for ever to load.
    if i  remove it, it opens  fast  as usual.
    Please don't tell me  that it could be a  Google problem  thatis loading slow  because it's not.
    the font file isnt  big enough either.
    Of course i have deativated the "load things from external urls" setting.
    any ideas on how could this be  fixed withoput changing my work style ?
    May 4, 2013 12:01 PM   in reply to chaos_avatar
    Here's the thing.  Links to external scripts on other servers often look for a user agent (browser identifier).  DW is not a browser so it can't send user agent info.  When it tries to connect with the external site and doesn't get an immediate reply, it hangs.
    A few options:
    1. Comment out the offending code until you're ready to publish the site.
    2. Disable CSS.  View > Style Rendering > untick Display Styles.
    3. Use a Design Time Style sheet without the @ import rules.
    The latter 2 will not effect Live View or Preview in browsers.
    Nancy O.
    May 4, 2013 12:20 PM   in reply to Nancy O.
    Thank you very much  for your time and thoughts Nancy!
    i would like you to help me  finding the option  you mention here:
    i could not find it in my spanish  dreamweaver (i never meant to have a spanish  dreamweaver  but it happened), tried to  find an option  similar to "display Styles"
    http://screencast.com/t/EPwy7uLXh
    in my particular case i always work in code view, i always code CSS in code view. Never use / nevwe will use design view. I wish a  way to  get DW  to NEVER try to connect to the external source because i  will never want to  see the work on DW itself.
    btw... The options  1 and 3  semms to me pretty uncoonfortable because they mean a lot of extra work.
    May 4, 2013 1:14 PM   in reply to chaos_avatar
    See screenshot:
    Nancy O.
    May 7, 2013 10:30 AM   in reply to Nancy O.
    Thank you very much for your time! Very  apreciated.
    For the record,  option 2 does not work. Since the problem happens  when opening the  css file directly.
    I work  with  hundreds of sites and i have to be  constantly and wildly opening and modifying many of them , many times a day.  so option  1 is completely out of the  posibilities  for me .
    Perhaps these  solutions  could  help other  people that works with less sites and don't mind adding extra steps to their workflow.
    i think  there must be a 4th option  to add:
    4.- go and make a cofee while DW opens the file.
    Aug 27, 2013 7:38 PM   in reply to chaos_avatar
    I was hoping the latest update to Dreamweaver CC would improve this but alas, no. This is still a problem.
    To simply *open a single html file*, nothing else, (with 'Enable Related Files' turned OFF in prefs),
    ... takes 10 seconds in Dreamweaver CS6 (v12.2)
    ... takes 14 seconds in Dreamweaver CC (v13.1)
    Computer is a 27" iMac 2.8GHz Intel Core i7, running OSX 10.8.4 with 12GB of Ram.
    Adobe, I have zero interest in new features. Unless the new feature is making the app run faster.
    Aug 27, 2013 7:51 PM   in reply to c41
    And in an effort to help Adobe, if I remove links to local css files within my project from the html file I'm trying to open (no @import font-face links in the css), the I can get the html file to open within 1-2 seconds.
    So to me - the "Enable Related Files" setting is not doing what I'd expect. When I open a file (with Enable Related Files set to OFF) it's still taking a look at linked files and checking stuff, which is slowing it down. I just want DW to open the file, and display it quickly. Perhaps lazy-load in whatever logic/checking you are doing to linked files after I open it.
