StefaanVanMieghem
Add multiple unknown attachments
Jun 26, 2012 6:22 AM
I have been trying to create a process to add multiple document level attachments (images), count and filenames unknown at design time.
Any examples?
I am at the point where I have a loop through the list of documents (attachments), setting the current attachment and its filename in a variable, then calling AssemblerService.invokeDDX for each.
The DDX validation tells me "process:///process_data/@currentFilename" is not a valid filename.
I have tried with listOfFilenames[/process_data/currentIndex], even process:///process_data/listOfFilenames[1]. All fail to validate.
I'm not sure the FileAttachments source gets the correct value either.
<DDX xmlns="http://ns.adobe.com/DDX/1.0/">
  <PDF result="pdfOut" format="PDF">
    <PDF source="pdfIn"/>
    <FileAttachments source="process:///process_data/@currentAtt">
      <File filename="process:///process_data/@currentFilename"/>
    </FileAttachments>
  </PDF>
  <?ddx-source-hint name="pdfIn"?>
</DDX>
Using Livecycle Workbench v9.5.
    Oct 14, 2012 3:56 PM   in reply to StefaanVanMieghem
    Hi
    So you want to add  x number of attachments to a documents using assembler.
    This can be done by using the DDX. Can you please send me your process lca to
    Mergeandfuse@ gmail.com
    I will fix your problems and send it back to you
    Workflowuser
