Photoshop Elements won't open. I have tried re-installing. I have windows pro 7
Version 9.
Welcome screen opens. I hit edit button. Clock turns and turns and turns,
but nothing ever happens. Edit never launches. Organizer seems to work, and
when I go to Fix from Organizer, I am unable to open Edit Photos. However,
the other Fix options seem to work.
I have re-installed several times, updated, etc., but there is no change.
The software worked fine up to the last 8 months, when it assumed its
present state.
Wayne
Try making a direct desktop icon for the Editor and see if you can launch the program directly from the desktop. Right click anywhere on the desktop and select New à Shortcut Browse to Computer OS C: And find the PSE Editor application in Program Files or Program Files (x86) on Windows 7 - 64 bit. C: à Program Files à Adobe à Photoshop Elements 9 Within the Photoshop elements 9 folder find PhotoshopElementsEditor.exe (with the blue icon) Select that file and click Next. Then click Finish. You should now be able to launch by double clicking on the new desktop icon, bypassing the welcome screen.
Hello:
Thanks for the advice. However, once I had the shortcut in place, and I
double clicked on it, the response was an error message: "Adobe Photoshop
Elements has stopped working"
"Windows is checking for a solution to the problem."
I tried restarting the computer, and hitting the icon again, with the same
result.
Incidentally, I do have 64 bit.
Wayne
The editor saved prefs often get corrupted. You may need to rebuild the editor preferences to resolve any conflicts. Hold down the Ctrl+Shift+Alt keys and simultaneously double-click on the Editor icon on the desktop. Release the three keys and look for a pop-up (you may need to minimize other windows) You should see a pop up box with the words: Delete Adobe Photoshop Elements Settings File? Click on Yes Then wait whilst Elements rebuilds the preferences.
try this:
1. update the product first
in organizer click on help> updates
2.
go to this path:
C:\Users\[Username]\AppData\Roaming\Adobe\Photoshop Elements\9\editor\adobe photoshop elements 9prefs.psp
move the file to the desktop
(at times appDATA is not showing, you go to organize tab on the left side of the screen and click on folder and search options > view tab>inside advanced settings box select show hidden files, folders and drives
and uncheck hide extensions for known file types
>apply>ok -check if appdata is showing)
then try to open editor
the 2nd step is the the same as what 99jon is suggesting, his is shall i say the shortcut method of resetting preferences, so since the shortcut did not work for you, to reset preference file, we just need to move the adobe photoshop elements 9prefs.psp file to the desktop
you need to go to computer> drive c > users folders>(username to log in to computer)........, you have to locate the file and move it to the desktop and launch your editor
hope that helps....
If you followed 99jon's method of re-setting the Preferences and answered "Yes" to the prompt to delete the Preferences, that's that -- you've already re-built the Preferences, so it's time to move on.
Please answer 99jon's questions about whether the Editor used to work and if you've installed any plugins.
Ken
Elements worked fine up until about 8 months ago. I have reinstalled
numerous times and tried to get it to work. I am sure I have installed
something over that time period, but I have no idea what it might be. I
dont add much to my system. I would have thought Elements would be a pretty
stable software, but possibly not.
Wayne
Well, actually it is very stable. We need to find out what's causing the error on your system.
Can you remember anything you did 8 months ago, such as installing any PSE plugins?
Let's see if the Windows Event Log can shed some light on this: Start...Control Panel...Administrative Tools...Event Viewer. Expand the "Windows Logs" folder in the left panel and select the "Application" log. Look for the most recent item with a red icon and that refer to Photoshop Elements. Copy the error info into a message here.
Ken
Here is a typical error from the last few days, as I try to get PSE
operating:
Faulting application name: PhotoshopElementsEditor.exe, version: 9.0.3.0,
time stamp: 0x4d906921
Faulting module name: PhotoshopElementsEditor.exe, version: 9.0.3.0, time
stamp: 0x4d906921
Exception code: 0xc0000005
Fault offset: 0x004003d0
Faulting process id: 0x1f0c
Faulting application start time: 0x01cd557351da7eab
Faulting application path: C:\Program Files (x86)\Adobe\Photoshop Elements
9\PhotoshopElementsEditor.exe
Faulting module path: C:\Program Files (x86)\Adobe\Photoshop Elements
Report Id: 9195405c-c166-11e1-a2c3-74f06da862f0
Wayne
I'm out of ideas, except for this last one -- your printer driver might need to be updated. See this Adobe troubleshooting document:
http://kb2.adobe.com/cps/408/kb408850.html
Ken
Hello:All printer drivers seem to current (HP is an unusually good supplier
- at the top of the heap, as far as I can discern).
I tried to maneuver to the url provided, but I could not find a twain plug
in. When I double clicked on import-export, I got the following:
An icon followed by Save for Web (EL).8be
That was all.
Wayne
North America
Asia Pacific
