MPDTrainee
Different behaviour on Mac/Win
Jun 28, 2012 8:31 AM
Tags: #illustrator #photoshop #indesign #creative_suite #csawlib #extension_builder
Hello,
I'm currently working on a Creative Suite Extension, which will show a collection of images on a panel (InDesign, Photoshop and Illustrator).
I need the application's path in a few javascript files and I'm getting weird problems on our testing-Mac. I have reduced the code to as few lines as possible, to show the problem.
Currently I'm using Photoshop CS5.1, Flash Builder 4.6 and Extension Builder 1.5 on my windows machine.
This is the code:
<mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                initialize="initializeHandler()">
    <mx:Script>
        <![CDATA[
            import com.adobe.csawlib.photoshop.Photoshop;
            import com.adobe.photoshop.*;
            protected function initializeHandler():void
                var app : com.adobe.photoshop.Application = com.adobe.csawlib.photoshop.Photoshop.app;
                if(app.path)
                    myLabel.text = app.path.nativePath;
                else
                    myLabel.text = "app.path was null";
    </mx:Script>
    <mx:VBox height="100%" width="100%" verticalAlign="middle" horizontalAlign="center">
        <mx:Label id="myLabel"/>
    </mx:VBox>
</mx:Application>
On my Windows machine myLabel shows the installation directory's path. On our Mac app.path is null, so it does not work.
I have tried many different approaches to solve this, but it doesn't work yet. Here are some ideas of what I tried so far:
- Get the path in Javascript instead using app.path.fsName (app.path is null on Mac in Javascript too, at least when it's called by the initialzeHandler)
- Put a timer in the initializeHandler, wait 10 seconds and try to get the path then (not a good idea and app.path is still null)
- Put a button on the panel that executes the initializeHandler instead. (app.path is working, but I need this to work without user interaction).
Can somebody enlighten me please?
Btw. I'm a developer trainee so it is likely that there is a simple solution or an obvious mistake, feel free to point them out.
    Jun 28, 2012 11:34 AM   in reply to MPDTrainee
    for what is worth, with Extension Builder 2.0 (Flash Builder 4.5.1) on OSX Lion, the following works:
    package
              public class ZPhotoshop
      public static function run():void
                                  var app:Application = Photoshop.app;
                                  if(app.path) {
                                            trace("App path is: " + app.path.nativePath);
                                  } else {
      trace("null path");
    (this is in the .as file that EB creates by default)
    The result is:
    App path is: /Applications/Adobe Photoshop CS6
    Regards,
    Davide
    Jun 29, 2012 1:14 AM   in reply to MPDTrainee
    Hello,
    actually it was on triggered by a button click, but I've tested moving it inside an applicationComplete (which in turns calls the run() function) and it works as well.
    Davide
    Jun 29, 2012 4:28 AM   in reply to MPDTrainee
    I'd say you have two options:
    1) Use ExtendScript to get the path.
    2) Add a short timer on CreationComplete and get the path on the timer event.
    Harbs
    Jun 29, 2012 5:43 AM   in reply to MPDTrainee
    MPDTrainee,
    this last example you've posted is referred to Extension Builder 1.5 or 2.0?
    If you can, you'd be better upgrading.
    Cheers
    Davide
