This discussion is locked
FAQ: How to Create Sprite Sheets?
Jul 15, 2012 10:39 PM
Tags: #a #flash #create #to #how #professional #cs6 #sheet #sprite #creating #starling #sheets #easeljs
Flash Professional CS6 allows you to export your Flash assets in to Sprite Sheets thereby optimizing performance significantly.
To create a sprite sheet:
  1. Select one or more symbols in the Library or symbol instances on the Stage. The selection can also contain bitmaps.
  2. Right-click the selection and choose Generate Sprite Sheet.
  3. In the Generate Sprite Sheet dialog box, select options and then click Export.
For more information, see Create a Sprite Sheet.
Also see:
http://blogs.adobe.com/flashpro/2012/07/12/spritesheet-flashpro-starli ng/
