brhurley
ExtendScript Toolkit cannot launch InDesign CS6 Server
Jun 29, 2012 9:45 AM
Tags: #extendscript #cs6
I have installed the trial version of InDesign Server CS6 on Windows 2008 and am trying to run scripts against it using the ExtendScript Toolkit, but it is not working. When I select "Adobe InDesign CS6 Server" from the drop-down list in the upper left, I get an alert box that says "Cannot launch target Adobe InDesign CS6 Server!". When expanding the details box it just repeats that same message.
I can start InDesign fine using either the command line or the windows service and it responds to requests. As far as I can see, it is just ExtendScript that is having problems with it.
I have combed through the event logs and can't find anything there indicating what the problem might be. I have also googled everything I can think of looking for a solution with no luck.
Has anyone else run into this? Any suggestions on a solution or at least where I might be able to track down a useful error message that says why it can't launch InDesign?
Bookmarked By (1)
