Adobe Premiere Pro Help | Organizing assets in the Project panel
Jun 30, 2012 6:44 AM
    Jun 30, 2012 6:45 AM   in reply to Community Help
    Bin tip
    When multiple bins are open, to close them all at once instead of one by one.
    Alt + Click on the triangle of an open bin.
    To open all bins at one: Alt+click on a triangle.
    Alt+click also works for the fixed and added effects in the Effect Controls Panel.
    Aug 30, 2012 9:48 PM   in reply to Community Help
    These videos are really solid, but if anyone is still confused, here's one more explanation of asset management from Adobe Certified Expert Jeff Sengstack of InfiniteSkills. If it seems basic, that's because it's targeted toward beginners:
    http://infiniteskills.com/blog/2012/08/adobe-premiere-pro-cs6-tutorial -managing-assets/
    Jan 17, 2013 11:27 AM   in reply to chrisjohnsskills
    Can you tell me how to make a clip?  I understand how to organize clips, but how do you grab a few seconds from your footage to make as a clip and put in a bin?  Ken
    Jan 17, 2013 2:53 PM   in reply to kenashe
    One way is to make a subclip. Open your footage in the source window. Set the I/O points. Rignt-click and choose Make Subclip.
    Feb 10, 2013 5:29 AM   in reply to Community Help
    For some reason I cant seem to use the search box in the project panel, its always grayed. How can i fix this?
    Feb 10, 2013 11:04 AM   in reply to BaaMCDOLE
    If you have opened a 5.5 project in CS6 you may experience the project panel search filter to go gray and restrict availability.
    Try to save and restart.
    If this doesn't work, then try to start a new PProCS6 project and import the 5.5 one, be sure to select "Entire Project" at the dialog box.
    Other people have noticed this too. It might be related to unindexed items - if Premiere Pro CS6 doesn't finish indexing the clips, it won't let you search. This is something that may require a bug report. See the link below.
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Or, you might be running into the problem discussed in this forum thread:
    http://forums.adobe.com/message/4666238
