Clipping paths
Jul 2, 2012 3:46 AM
Branched to a new discussion.
    Jul 2, 2012 3:46 AM   in reply to Community Help
    I want to apply it to a simple shape. But I can't. Clipping Paths sub-menu is greyed out. Why...?
    so it's a simple rectangle, I want to effectively cut an arch into the bottom of it...
    Jul 2, 2012 5:39 AM   in reply to Jay_0993
    Clipping paths are used on images, not shapes. To modify your shape you can use the pen tool, or use the Pathfinder panel to add or subtract one shape to or from another.
    Jul 2, 2012 5:35 AM   in reply to Peter Spier
    Ah - spot on! Thanks :-)
    Apr 7, 2013 1:46 PM   in reply to Community Help
    Clipping Path is an initial technique commonly used to take out targeted object from its background. A great tool in Photoshop, “Photoshop Pen Tool” is used to create an outline around an object is called Clipping Path when its active.
    Apr 15, 2013 11:35 AM   in reply to Community Help
    Can I combine alpha transparency with a clipping path on the same image in InDesign?
    Cheers,
    James
    Apr 15, 2013 12:10 PM   in reply to jmunki
    When you invoke the Object > Clipping Path command in InDesign, it makes a path according to the basis you choose from the Type menu in the Clipping Path dialog. If the image already contained transparency via Photoshop layering, or an "alpha channel," that transparency, is of course, also preserved. So yes, you can have native transparency plus an InDesign-generated clipping path on the same image.
