Hello, I'm having a Captivate 5 problem and can't seem to find an answer on the web or in the forums. I'm creating a quiz in which I'd like to ask multiple choice questions. For each answer option I'd like the user to be able to click on something - the answer text, an additional image, something - that would open a web page in a separate browser tab or window. That new window would contain information related to the linked answer option. This way the users can assess the relevance of each option in relation to the question.
I've tried using the "Advanced Answer Option" option but that only opens a window when the answer is submitted. Before I sat down to do this I was thinking I'd just add image buttons on the page, but it turns out that I can't add buttons, text inputs and several other options in a quiz slide.
If anyone has any ideas on how to work around this I'd really appreciate hearing them. Thanks in advance for any help you can give.
Correct - you cannot add interactive objects to a question slide.
You could build your question using clickboxes for the multiple-choice
question, instead of using the standard quiz slide.
Alternatively, I think you can add a Button Widget to a quiz slide. You can
create your own button widgets in Flash.
Steve
Hi Steve, thanks so much for the quick reply!
The Button Widget does the job admirably, I can add it in and even make it invisible with the alpha setting so it appears that an image is the actual link. Totally lets me do what I wished!
Thanks again!
Dave
Hi Dave,
Just to inform you that in CP6, we can add smart shape as a button to quiz slide, and set actions to it ( open url or file etc).
Regards,
Avinash
