Audition 3 crashes when accessing the Audio Hardware Settings menu item. Need to change the setting
Jul 2, 2012 6:45 PM
I had to change my asio audio driver and now Audition 3 crashes when I try to access the Audio Hardware settings window. Multitrack plays but no sound so I have to change the output settings. Is there any way I can access the settings without going through Audition. Basically, I'm down till I get this happening causes the program crashes.
(rolling back a driver is not an option)
Thanks for any help.
  • SteveG(AudioMasters)
    Oct 26, 2006
    Jul 3, 2012 3:38 AM   in reply to ozworldz
    Firstly, we have no idea of what your hardware is here, or indeed your OS. But if you are experiencing a crash when you access the settings window in Audition, then you have one of the following: An OS fault, an Audition fault, or a driver fault. Other than reinstalling everything, the only thing you can try doing is to delete all of the Audition preferences files and folders (info in the FAQs), and see if that makes any difference. Personally I think that this is extremely unlikley in this case, but other than reinstalling absolutely everything, it's the only option you have.
    What happened immediately before this all went wrong?
    Oct 26, 2006
    Jul 3, 2012 12:27 PM   in reply to ozworldz
    ozworldz wrote:
    ps..I'm now trying to install Audition CS6..but it's day 2 and it's still installing (crazy), we'll see how that works.
    Something happening in your OS is hanging the install, big time. Audition CS6 install takes a few minutes in a system that's working properly.
    Since you're in XP, go Ctrl-Alt-Del and a) firstly see how long it takes to get to the Task Manager, then b) look at the running processes and see which one's jammed somewhere around 99.9%. Also, could we have an idea of how many processes are running in the background?
    One other thing you could try doing (and it really isn't worth continuing with the install, not after this long) is to do a system restore back to a point before you installed the second mixer's driver, and see if the OS responds more sensibly.
