Fill in colour for repeating subforms
Jul 5, 2012 11:24 AM
I have a repeating subform with max count 5 subforms.
Is it possible the 4th and 5th repeating rows to have another fill colour?
Here is the script I use for the Add Instance button:
_Item.addInstance();
Thank you
Here is the script I use for the remove Instance button:
if
(_Item.count > 1)
_Item.removeInstance(this.parent.index);
Item is a row in a table.
    Jul 5, 2012 3:10 PM   in reply to mmgiath
    First off, I would not be inclined to name an object/subform "Item". It is very close to a reserved word "item".
    Also in the addInstance() method, you should pass a parameter. The default is true.
    One route would be to use the layout:ready event of the repeating subform. This is not very efficient, as the layout:ready event fires so often as the user interacts with the form. However it will deal with situations where rows are added and removed.
    if (this.parent.index >= 3) {
         this.fillColor = "255,129,129";
    This might give you a start,
    Niall
