• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
External SWFs Not Getting Added When Movie is Published
New Here ,
Jul 05, 2012 Jul 05, 2012
What would cause external swfs to suddently not display when a movie is published?
My external swf's are getting loaded and added to the stage when I test/ CTRL + Enter the movie, but when I Publish/ F12 the movie directly in Flash, or import the main swf into Dreamweaver and publish my page from there, my external swfs are not showing up.
I've three external .swfs, one is a collection of buttons, the other two each contain TLF Text dynamic text fields.
TOPICS
ActionScript
Views
849
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
If your swf is located in a separate folder than the html page that loads it, that can be the source of the problem.  Anything an swf file loads needs to be targeted as if that swf is in the same folder as the html page that embeds it (it doesn't have to be in that same folder, it just has to act like it is).
Votes
Translate
Translate
Report
Report
New Here ,
Problem solved. I basically started from scratch, moving bits and pieces of the movie to a new version.....
You were of course correct, Ned, regarding the location of the main .swf in relation to the html page that loads it -- that was my first mistake.
I got the gist of the rest of your explanation when I did a little "substitution" in my mind when looking in each of the external .swfs at the path in relation to the main movie's .swf.
Here's my folder structure:
index.html
mainMovie.swf
     /assets
          /content/
                   bio.txt
                   news.txt
          /css/
                   bioStyle.css
                   newsStyle.css
                   siteStyle.css
          /fla/
                   bio.swf
                   networks.swf
                   news.swf
I think my troubles sprang from my calling and loading the related .txt and .css files from the movies themselves, bio.swf and news.swf. In each of the movie's frame 1 I would use the path...
var newsURL:URLRequest = new URLRequest("../content/news_10Feb2012.txt");
thinking because the individual movie was doing the calling and loading the path would need to go from the movie, out of the fla directory and into content.
.... If I instead used
var newsURL:URLRequest = new URLRequest("assets/content/news_10Feb2012.txt");
the movie would publish.
From a best-practices perspective should I be calling and loading related .txt and .css files from the individual movies, or from the main movie, keeping the external swfs empty save for the text fields, scroll bars, background images, etc.?
Votes
Translate
Translate
Report
Report
LEGEND ,
Jul 08, 2012 Jul 08, 2012
When it comes to what is best put where you should try to think interms of functional divisions.  Ideally, any file you create as a separate swf should be able to be adated for use with any number of other applications.
Just as an example, if one happened to be an mp3 player, then it would be beneficial for you to be able to take that and re-use it at will.  So in that sense, it would probably be better to have the files it uses to be processed from within it.  But to make it portable/adaptable, you would probably also want to have the ability to feed data to it to define the files that it should target.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks.
Votes
Translate
Translate
Report
Report
Guide ,
How are you "adding" the swfs? Are you using a Loader? Embed metadata? Something else?
Votes
Translate
Translate
Report
Report
