TOP FOTO
Sony m2ts files had sound but now they don't
Jul 6, 2012 4:52 AM
Tags: #no #audio #sony #premiere #import #sound #m2ts
Hello.
I was working for a long time on a PC with Pinnacle Studio 14.   This worked fine with m2ts files from my Sony HDR-SR8 although the output always disappointed me, it seemed soft or it seemed to have lines in it depending on what settings I tried.   I wanted to advance my video editing skills, knowledge and ability so I went with Avid Studio.  This would not work properly on my PC and was left to rot on the hard drive.  So I decided to get through the learning hump and go for Premiere (and later the intention of learning After Effects too).
Premiere Pro CS6 trial worked with the very same m2ts files that I used in Pinnacle.   I made a few simple home movie projects and mostly I was thrilled with the perfect output quality that encouraged me to go on using it.  At some point I decided to get rid of the other software that I was no longer using to free up hard disk space.  I removed Pinnacle Studio 14 and Avid Studio and another few unrelated bits of software that I considered unused and redundant.   Now Premiere won’t play the sound from the m2ts files.  The same ones that I used before in Premiere won’t play sound now.  The only real clue I have is opening an old project that I was working on.  I get this error message:
“This project contained a sequence that could not be opened.  No sequence preview preset file or codec could be associated with this sequence type.”
Thinking that some codecs were removed I re-installed Pinnacle and Avid.  No luck.  Thinking that they were installed first ahead of Premiere I removed everything, reinstalled pinnacle, then avid, then premiere.  No luck.  I’ve tried loads of combinations.  I downloaded and installed CCCP codecs again.  I installed the Premiere update 6.0.1.  No luck.  I've removed all Adobe products, run the Adobe cleaning tool, did restarts etc etc etc.
So the facts is Premiere did work properly on this pc.  So whatever is wrong is something small like a codec missing or a missing registry entry.
    Jul 6, 2012 5:57 AM   in reply to TOP FOTO
    That seems like a logical conclusion. The question remains however, which codec is missing? What does MediaInfo tell you about the codec in use?
    Jul 6, 2012 8:26 AM   in reply to TOP FOTO
    Well, the source material was HDV, but the material you are using was encoded to BRD format, using 5.1 audio and it not suitable for editing. I would try to get the original footage from the copyright owner.
    Jul 6, 2012 9:11 AM   in reply to TOP FOTO
    MediaInfo is accurate -- the source footage from the camera is AVCHD that looks like it's in a M2TS wrapper.  The camera records to an internal HDD, so maybe Sony decided on the BD file format because of that.
    Check Premiere Pro's preferences for your audio channel mapping settings, check to see that your sequence has at least one 5.1 audio track, and also check Windows audio settings that your sound card is set to downmix multichannel audio to stereo audio (unless you have a 5.1 speaker set up).
    Jeff
    Jul 6, 2012 9:18 AM   in reply to TOP FOTO
    I had a similar situation occur recently.  What fixed it for me was two things.  I had to reactivate Premiere Pro, and I had to clear the cache entirely.  The first allowed the codecs to 'reregister", and the second forced PP to create the cache files.
    Jul 6, 2012 9:54 AM   in reply to TOP FOTO
    Un-install it again (sigh).
    You don't necessarily have to uninstall.  (I didn't.)  Just deactivate, shut down PP, reboot, restart PP and reactivate.
