RH9 | WebHelp
When I generate a PDF of any topic by previewing it (in RoboHelp), right-clicking, selecting Print and then Adobe PDF in the Print dialog box, the output is substituting my normal font Tahoma for Courier. However, it leaves anything in bold type. See the screenshot below:
This is a fresh install of Technical Communications Suite 3 on a new laptop and it's the first time I've produced a PDF this way.
Any help would be much appreciated.
Jonathan
What operating system is being used? If XP, then you probably need the MS Hotfix. Are you fully patched up on your TCS components?
I'm running Windows 7 and I'm fully patched up. This method worked fine on my old desktop PC too.
Correction - RH is fully patched up, but Acrobat wasn't. I've updated, restarted, and all appears well now. Thanks Jeff.
