Tutorial on converting raster drawings to vector
Jul 6, 2012 8:48 AM
I have a friend who does drawings on paper that he wants to get scalable.  The high-level path appears to be scan the image and run autotrace in AI.
As I look at online articles, some suggest taking the raster into PS to erase the pencil marks and ink the image.  My friend does the inking on the paper before the scan.
I have some experimenting to do with autotrace settings, but I can see right away that some of the lines on the image vary in width in both PS and AI.  And, no matter how good his inking is, there is still quite a bit of "noise" along the lines.  His inking also leaves quite a bit of variation in line width.  What he wants is a constant width.
My question is: if you want a line to be of constant width and you have a scanned image to work with, which tool (PS, AI) and what technique is best to create the result.
One thought is, rather than try to clean up the line in either tool, the better approach might be to draw a new line using the scanned image as a guide.  My concern is that the line won't be smooth if done by hand.  Are their tools in either PS or AI that would help?
Thanks, and sorry this is a bit vague.  I'm just starting to understand the issue.
Tom
    Jul 6, 2012 10:44 AM   in reply to TCarp
    This may not help you but when you click the drop down menu under live trace, try clicking tracing options rather than any of the presets. From there, you should click the preview button and then make your changes withing that window. This will help you see the adjustments you're making in real time so that you can get it just the way you want with as little frustration as possible.
    Jul 6, 2012 10:51 AM   in reply to TCarp
    You might want to use something like this
    Aug 24, 2012 5:39 AM   in reply to Larry G. Schneider
    This is something new idea you have given. I will try this experiment. I likeed your tutorial of converting raster drawings to vector.
    oil portraits from photos
