Bridge's parent application is not active
Jul 7, 2012 10:53 AM
I've suddenly come across a problem with Adobe Bridge where it isn't allowing me to open .CR2 files into Camera Raw. When I right click on an image in Bridge, an error message pops up:
"Bridge's parent application is not active. Bridge requires that a qualifying product has been launched at least once to enable this feature."
Originally, I opened Photoshop CS6, then File > Browse in Bridge. I've have opened ACR hundreds of times on this computer so I don't understand why it wants me to open it to be able to use it. I've opened a RAW file from Windows explorer, but when going back to Bridge, the same error occurs.
Does anyone know what the problem is here and how to fix it?
Running Windows 7, Photoshop CS6 64-bit, ACR 7.1, Bridge CS6 64-bit.
Thank you!
    Jul 7, 2012 12:56 PM   in reply to Synchronization
    If it worked before I would reset preferences.  Hold down Ctrl key and start bridge.  Should get a reset window.
    Jul 12, 2012 6:02 AM   in reply to Synchronization
    Hi
    I've got the same problem. I updated to CS6 2 days ago and everything was fine until now.
    If I double click a Raw file inside Bridge, it opens within Camera Raw.
    It won't open a JPG the same way. I get the same error, "Bridge's parent application is not active. Bridge requires that a qualifying product has been launched at least once to enable this feature."
    The only way I've found to open a JPG' in Camera Raw  which is a pain,
    is to go into Photoshop,
    File,
    Open As,
    navigate to the image you want to open in Camera Raw,
    expand the lower drop down list,
    select Camera Raw,
    then Open.
    The jpg will now open inside Camera Raw.
    If anyone has a quicker way then I'd appreciate it
    Graham
    Jul 12, 2012 7:18 AM   in reply to coatesy69
    coatesy69,
    In edit/camera raw preferences do you have jpeg set to automatically open with settings?
    Jul 12, 2012 7:22 AM   in reply to Synchronization
    You need to think back to what has changed since it worked in ACR.  Did you add any software, hardware, major update in anti-virus, driver, change file loaction in Adobe, etc.
    Jul 12, 2012 7:57 AM   in reply to Curt Y
    Hi
    Yes I do have those checked
    I can edit Camera Raw preferences from inside Photoshop but if I click on Camera raw preferences inside Bridge I get the same message
    Jul 12, 2012 8:25 AM   in reply to coatesy69
    You problem is long standing.  There is no one answer as it is something on your computer causing the problem.  It is looking for another program to launce Bridge.   Have you had any Adobe trials that have not been unistalled?
    Jul 12, 2012 9:48 AM   in reply to Curt Y
    Hi
    I Have sorted it out.
    It was what you said about a trial. I subscribed to Photoshop on a yearly basis and activated it online. Then for no reason a trial box kept popping up.
    I phoned Adobe who managed to get it sorted. Now I can open Jpegs in Camera Raw through Bridge.
    Thanks for your help
    Graham
    Aug 15, 2012 1:27 PM   in reply to Synchronization
    If anyone else is still having this problem, I've found a simple solution. Go to the Bridge folder in Program Files. Rename AMTLib.dll to AMTLib.dlx. COPY (I mean copy, don't move) the atmlib.dll file from the Photoshop folder in Program Files to the Bridge folder. Restart Bridge. Problem should be solved!
    Sep 4, 2012 9:54 PM   in reply to frodoboy
    Didn't work at all. I simply cannot start Bridge at all. Is there anyplace I can take my computer to have someone fix this?
    Sep 5, 2012 7:13 AM   in reply to Tim Repp
    What OS?  Several users with Mountain Lion OS have found CS2 and possibly CS3 caused Bridge from opening.
    Sep 5, 2012 9:39 AM   in reply to Curt Y
    I finally got it to launch via instructions from another web page. In my case, I am running Win 7 Professional 64-bit and previously loaded Photoshop and Bridge versions CS2 (along with Illustrator and InDesign CS2), which might have been part of the problem. The solution for me was to create an empty "Bridge CS2" folder in the C:\Users\[your user name]\AppData\Roaming\Adobe\. Worked like a charm.
    Nov 17, 2012 12:04 AM   in reply to Tim Repp
    Did not work!
    Nov 30, 2012 7:05 AM   in reply to MontyPython
    I did read about a solution that worked for people who had used a crack
    where you change the amtlib.framework folder for every CS6 application.
    So this only applies if this is what you've done.
    If you did the same for Bridge and replaced its amtlib.framework folder,
    go back and put back the original files and it should work fine.
    Dec 23, 2012 7:46 PM   in reply to Synchronization
    Don't go fooling around with the Amtlib.dll files. Just go to Photoshop/File....... Open As..... Scroll down to the image you require and choose the box with Open As Camera Raw. This works so you don't have to try and solve a problem that has no solution that I can see, apart from reinstalling. This method is easy and takes very little time.
    This problem only came to my system after updating Photoshop.
    Dec 24, 2012 11:40 AM   in reply to ultra2442
    Interesting that you would say that. I did the "fix" and have never had any
    problems and I don't have to do an "open as" as you suggested. The Amtlib
    dll fix has permanently solved the problem even with updates. It just got
    corrupted somehow with an earlier update.
    Mar 14, 2013 10:51 PM   in reply to Synchronization
    I found this answer while listening to lynda.com Advanced Adobe Photoshop Class Camera Raw Chapter.
    The answer is simple.
    Open Bridge
    edit
    preferences
    under behavior section in middle of options click double click edits Camera Raw settings in Bridge.
    click ok
    It must be a double click on the pictures in bridge to open pictures in camera raw.
    I just tried a single click and the same error message came up.
    The results of this modification mean in english that bridge will no longer care about it's parent Photoshop being opened or not.
    Hope this helps.
    James
    Mar 19, 2013 9:08 AM   in reply to jamvan08
    That's not the answer to this problem James.
    This bug started this morning on my Mac (10.7.5) and it's driving me nuts. I've guessed it's something to do with my Creative Cloud subscription. There was a payment error that cancelled my subscription (since fixed) and now, despite renewing the sub and reinstalling after using the uninstallers and Clean Up, and updating, I have to sign in through a dialogue screen whenever I open CS6 apps to confirm I'm actually legit. Then, in Bridge, I get the dreaded "Camera Raw blah blah blah" message when trying to open files in ACR by pressing 'cmd-R' or going to File > Open in Camera Raw. If I double click a CR2 or RAW file it opens up fine. If I try to open the same CR2 or RAW, or a jpeg or tiff using 'cmd-R', it won't.
    If anyone feels like answering with "set prefs to automatically open all jpegs and tiffs with ACR. Hey presto!" or "use minibridge" or some other workaround then please do not waste your time. I don't want it to automatically open all jpegs etc with ACR, just occasionally, when I tell it to. Similarly, I don't want to use mini bridge in PS. What I want is for Bridge to do exactly what it has always done previously before this morning. I don't think that's too much to ask of Adobe but I notice this problem has been going on since 2008 with various versions of CS and no explanation or fix. Disappointing.
    Mar 19, 2013 9:38 AM   in reply to c-tips
    What seems to work with fixing "Adobe Bridge Parent Application Not Active" is to go in and uninstall any expired Adobe Trials.
    I think you are correct to assume it is related with the foul up of the Cloud subscription.  Do you have an unused version that is now considered a "trial"?
  • Omke Oudeman
    Nov 27, 2004
    Mar 19, 2013 1:40 PM   in reply to c-tips
    This seems related to an old thread and I'm using email to read and write to the forum. Can you clarify a bit more about the blahblah?
    You stated that it happened suddenly this morning and also mention a subscription trouble with the creative cloud. Did you use Bridge after the trouble was solved and it worked but stopped this morning or was it directly after you reinstalled everything?
    Did you already try the obvious restart Bridge holding down option key and choose reset preferences? The Clean tool is not deleting everything Adobe has installed before.
    And double check on the updates, the application manager sometimes has a mind of its own, especially when having multiple language versions installed, it only updates the language version set in preferences.
    And check PS the About Menu
    for about PS it should say 13.1.2 x64
    and about plug in / camera raw it should say 7.3.0.71.
    And in Bridge About Bridge it should say 5.0.2.4
    Can you confirm this and can you also report what other applications you have installed from the creative cloud.
    And since I changed to OSX 10.8 I can't check myself, is 10.7.5 the latest update?
