kjumaa
Commenting and Digitally Sign
Jul 10, 2012 6:11 AM
Tags: #digital_signature #incremental_updates
Dear Adobe Acrobat Team, I am adding an annotation and a digital signature to a pdf document through my being-developed application, however when open that pdf with adobe acrobat, it validates the signature, and reports that "Annotations Modified" under the validated signature in the signatures panel, so why do acrobat behaves that way?
    Jul 10, 2012 6:31 AM   in reply to kjumaa
    Moving this discussion to the Acrobat SDK forum.
    Jul 17, 2012 12:14 PM   in reply to kjumaa
    Without an example PDF that demonstrates the problem we can only guess…
    And my crystal ball is on the fritz this week ☹
    Jul 18, 2012 3:44 AM   in reply to kjumaa
    You did a standard signature and then commented.   You need to do a CERTIFYING signature with stipulate that commenting rights are enabled.
    Jul 18, 2012 4:34 AM   in reply to kjumaa
    I see the comment in the same update table as the signature, correct?
    Jul 22, 2012 4:59 AM   in reply to kjumaa
    Are you sure your signature is trusted by Acrobat?  You will also see warnings when you use a self-signed signature but don’t add it to the trust store.
    Jul 22, 2012 9:49 AM   in reply to kjumaa
    I am still seeing that the signature in Sample2 only applies to the original and NOT to do the annotated version. You can see this because Acrobat clearly allows you to pull the original version, which does NOT have the signature.
