Zabklamn
Premiere Pro CS4 problem with encoding video
Jul 10, 2012 3:18 PM
Hi, there. I appologize first if I had missed this or if I'm doing something completely wrong with the program. I only just started using it a few weeks ago and only know the basics of it.
onto the problem, I seem to be having difficulty encoding videos. See, I have a bunch of video clips that I basically imported in, edited down to the clip from the video that I want, and squeezed them into the timeline. The problem is, however, that whenever I export the collaga into the encoder and begin encoding, it takes the video clips and screws with them, putting them at random times in the entire video instead of the video clip where I wanted them. If someone could please help, that would be much appreciated.
I appologize beforehand if I am doing a beginner mistake, or if this is just a common glitch that everyone should know about.
Thank you for your time.
    Jul 10, 2012 6:22 PM   in reply to Zabklamn
    Welcome to the forum.
    What I think you are describing is odd behavior, and not something that I have ever encountered, or even read about.
    Let's step back a bit, and get a bit more info. What might be important would be:
    • Your Project's/Sequence's Preset?
    • A full description of your Source Footage - the more info, the better.
    • What you have done, in the editing - Effects added, etc..
    • The exact Export settings.
    Not sure that any equipment info would be needed at this point, but keep that in the back of your mind, just in case.
    Good luck, and please let us know a bit more.
    Jul 10, 2012 9:23 PM   in reply to Bill Hunt
    maybe also post a screen capture (image) of your timeline being exported. Do you have multiple video tracks active or just the one you are trying to export ?
    Jul 11, 2012 6:34 AM   in reply to Zabklamn
    yikes.
    Bill Hunt who asked you for info earlier knows more about this than me..so he'll have some ideas for you... so hang on maybe until he responds to what you posted before you do anything that I might suggest or say here...
    Basically your clips are various frame rates ( 23.97, 24, 29.97, 30 and even a 28.92 ( clip 4 ) ).  In a perfect world your clips would all be the same frame rate and also the same dimensions usually...
    The dimension problem you sorta solved by effect adjustment ( size / position ) and as long as your happy with results is OK. It's only quality of image that suffers from different dimensions and par... not the actual timing of the clips placed in the timeline.
    The frame rates being different kinda messes up things a bit.  If you think about it... if you have 30 frames in 1 second, and then you have 24 frames in one second... and they are both on the same timeline which gives you a steady single count of seconds...then the timeline count gets messed up... cause it can't stretch out the 24 frames to equal 30 ...and vica versa. Does that make sense ?
    You might be able to use "interpret footage" on each clip to make adjustments to the fps, in which case you would make everything equal to your sequence setting, in effect making your 24 fps = 30 ...or whatever your sequence was created at...
    In that way you artificially ( program does it as best it can ) change the fps to all the same ... and your export should then look good time wise... but the quality etc will maybe suffer a little bit...cause of all the hoops the program needs to jump through to try and make work out.
    Anyway, wait until Bill gets this info you posted and he'll help you out.
    Jul 11, 2012 5:30 PM   in reply to able123
    As a comment, PrPro CS 5, and up, handle mixed FPS, better than other, earlier versions.
    Before CS 5, I would always convert to a common FPS, either with a 3rd party program, AME (Adobe Media Encoder), or by doing one Sequence for each FPS, and then Exporting that to a common setting, and using those output files in another Project, or Sequence.
