Delete along a ND gradient?
Jul 12, 2012 7:25 AM
Tags: #issue #images #layers
Hello all
One of the characteristics of vertical aerial photography is a tendency for uneven exposure – even the latest million dollar + capture systems exhibit this problem. When you use 1000’s of these images to produce products you can end up with a striped appearance – not good. So along with other (IMO less successful) software tools we use Photoshop to try to address this issue. So far adding a neutral density gradient mask (layer) to the image helps a lot to even overall density. But when this initial unevenness also includes a loss of contrast on the light side you end up with an ‘even’ image that’s contrasty on one end and flat on the other.
So without adding a bunch of screen shots (right now at least) tell me if this can be done:
Image A is good contrast / brightness on left half, light and flat on right. Make image A copy layer. Adjust A copy so that right side ‘matches’ left side of A original. Create a new layer with a ND gradient that approximates what you want to keep/delete (doesn’t matter at this point) and use that as a ‘template’ (not sure if that’s the right word) to modify the image A copy. Like a layer mask?
Oh, one more thing - this needs to 'batchable'
Thanks!
    Jul 12, 2012 8:23 AM   in reply to TLL...
    I would like to ask for those screenshots or lores images now, because I don’t quite follow, I’m afraid.
    Jul 12, 2012 8:27 AM   in reply to TLL...
    To modify the contrast, try an Adjustment Layer with a gradient in its mask. A Levels AL or Brightness/Contrast AL may do the trick.
    Jul 12, 2012 1:29 PM   in reply to TLL...
    how do I save this adjustment layer/mask combo to apply to multiple images.
    Instead of saving the masked AL, you can record an Action of making the AL and its mask, then run that Action as a batch process on a folder of image files. If the images are all the same size and require the same gradient mask and Levels parameter values then only one Action will be needed.
    Consider first saving a custom preset of the Levels values that you want. Then when you record the Action, just add the Levels AL and select the preset from the dropdown above the Levels controls then make the gradient in its mask and, finally, stop recording
    You run a batch process from File > Automate > Batch...
    I think you can run it from Bridge, too, but I've not made much use of Bridge.
    Jul 12, 2012 3:34 PM   in reply to TLL...
    I used the Gradient Tool to make the gradient in the mask which was already targeted after creating the Adjustment Layer. The start and end locations of the gradient were included in the Action without enabling Allow Tool Recording. You might save a custom Gradient preset before recording the Action.
    Here's how the action looks in CS6 (I forgot to mention the Save As step earlier). It definitely works in batch mode in CS5.1 on OS X 10.6.8, too.
    Jul 13, 2012 7:33 AM   in reply to TLL...
    Great!
    I only discovered this forum a few weeks ago and it does seem incredibly quiet when you consider the millions of Ps users.
