Sharing library assets across files
Jul 12, 2012 6:32 AM
    Jul 12, 2012 6:32 AM   in reply to Community Help
    If an asset isn't used on stage (for instance, popups that you add to the program with getDefinitionByName/addChild), it seems that the AuthorTimeSharedAssets doesn't always update properly. Is there a way to manually update the link?
    Jan 18, 2013 10:55 AM   in reply to Amy Blankenship
    FWIW, if you go into the Symbol properties and uncheck "update automatically," then go back to the library and check the "link" box, this usually forces an update (and even allows you to say whether the shared or local symbol takes precedence).
    It also seems my issue wasn't that the assets weren't used on stage, it was that each xfl has its own subfolder (which is a bow to how FB expects you to structure a workspace when you're pointing to a Flash project).
    Mar 19, 2013 5:59 PM   in reply to Community Help
    Do the above "(CS5.5 only)" sections also apply to CS6 now?
    Jun 30, 2013 12:05 PM   in reply to Community Help
    How about somebody answer Amy after 3 months with her valid feedback.
    Jul 3, 2013 3:48 AM   in reply to Amy Blankenship
    Hi Amy,
    In Flash CC, Authortime Sharing of library assets has been removed and only Runtime Sharing is supported.
    If you are using CS 6, then you may right click on your shared symbol in the Library panel, select the Update option and manually do an update.
    @obssessless,
    Yes, the above "CS 5.5 only" section is applicable to CS 6 as well but not in Flash CC.
    -Nipun
    Sep 4, 2013 8:52 PM   in reply to Community Help
    How do I stop authortime sharing a symbol?
    Sep 5, 2013 10:15 AM   in reply to TerryNguy8n
    Follow the instructions above to force the link to update, but stop before you check the box again that would link it back.
    Dec 3, 2013 3:02 AM   in reply to Nipun Asthana
    The new update(Flash Pro CC release - November 2013) is now available to you; which has the Authortime sharing feature enabled. This Flash CC update will update your flash version to 13.1.0.217.
    You can update from the Adobe Creative Cloud application or from Flash Pro CC Help -> Updates menu.
    You will more information about the update at: http://helpx.adobe.com/flash/using/whats-new.html
    Sujai
    Adobe Flash Professional Team
