How to Create a shaded arch
Jul 13, 2012 2:42 PM
Tags: #illustrator #to #how #marks #arc #arch #hash #tick
Hello again;
I'm sure that this is probably old hat to you guys, but I have no idea how to create the arch part of the dials, at least I think it would be an arch.  With the top photo, the "arch" has 2 colors so I would need to have 2 layers, one holding one color and one holding the other color, but as I said I have no idea how to make them and I had no success with the "arc" tool.
In the second photo, it's very difficult to tell, but the left side of the arch is green and the right is a pale yellow so again, I think I would need two archs.  The second photo also these tick marks that are at the top of the arch and again, I have no idea how to recreate them.
I'm hoping someone that knows how to make these wouldn't mind putting together a step by step tutorial for me since I'm still a novice with Illustrator.  Thanks!!!
    Jul 13, 2012 3:14 PM   in reply to Jber505
    jber,
    In both cases, you may start with concentric circles corresponding to the outer and inner edges of the coloured parts and cut/divide them where the colourings end; you may delete superfluous parts.
    You may use radial lines to cut the circles; if you lock everything but the radial lines and the concentric circles to be cut, you may select the lines one by one and Object>Path>Divide Objects below.
    After dividing, you may colour the individual parts of the (remaining) circular rings.
    In the first one, you may give the tick marks a black stroke and ultimately place the coloured circular strips behind them; the stroke will only be seen on the background of the coloured strips.
    Jul 13, 2012 3:59 PM   in reply to Jber505
    Just use a stroked path for what you see a an arc. Like here
    Jul 13, 2012 6:25 PM   in reply to Jber505
    ... so I would need to have 2 layers ...
    Not necessarily. Sub-layers in a stack, yes, but for a simple job like this you shouldn't need more than one layer.
    It might help to drag ruler guides to mark the centres of your circles before you clip them. This will facilitate the positioning of the tick marks.
    Otherwise Jacob and Larry have got it right.
    Jul 14, 2012 3:11 AM   in reply to Jber505
    jber,
    What Larry and Steve said.
    Obviously, it is easier to use a simple stroked path.
    I was thinking of the precise sizing/positioning, against the outer/inner circle used for the tick marks part, but it is quite easy to adjust the circle size.
    You can still put the circular strips behind the tick marks.
    Hopefully without getting the tics.
    Jul 14, 2012 8:33 AM   in reply to Jber505
    As the others are saying it just paths and the way they obtain the arcs ar by actually creating an circle elipse and trimmiing them. You can use the scissor tool for that if you still can't figure it out then later if I have time I will do a small video.
    your get something like this
    Jul 15, 2012 3:24 AM   in reply to Jber505
    jber,
    To create a new circle with the same centre as an existing one, you may select the existing circle and Object>Path>Offset with a positve or negative value (to make a larger on or a smaller one).
    That will give you two concentric circles, and you may go on.
    If you wish to make a simple stroked path that touches an existing path, set the Offset to (+/-) half the desired Stroke Weight.
    If you wish to create closed paths based on inner and outer circles, set the Offset to (+/-) half the difference in Width/Height.
    In any case, you should keep copies of the circles that determine the tick marks; always keep copies of crucial steps in the creation of artwork, to facilitate/enable editing and further work, like this.
    Jul 15, 2012 7:52 AM   in reply to Jber505
    You are welcome, jber.
    I hope we shall see the final versions. Which models are they for?
    Jul 31, 2013 3:46 AM   in reply to Jber505
    Jber,
    Based on the two circles, you should be able to create a closed path as follows:
    1) With everything deselected, pick the Direct Selection Tool and click on a pair of corresponding end Anchor Points on the two circles, the Ctrl/Cmd+J to join them;
    2) repeat 1) for the other pair or select the newly formed path with the (normal) Selection Tool and join.
    Then you should be able to fill the newly formed partial circle, and remove the Stroke (if any).
    Jul 31, 2013 4:15 AM   in reply to Jber505
    Jber,
    As a fresh approach (which are at least in part represented in the earlier posts by different contributors) would be to (Smart Guides are your friends):
    1) Create a circle, concentric with the dial, with a Stroke weight corresponding to the desired width and a W/H to give the right size/position, and move it beneath the tick marks;
    2) For each desired end of the circle part, or for each end of a (differently) coloured portion of it,
    2a) If the end is under a tick mark (as the case in post #2): Select the circle part and switch to the Scissors Tool, then click each point in question where it crosses under a tick mark (Smart Guides will say intersect when you are there);
    2b) If the end is not under a tick mark, create a line that crosses it in the right place (you may drag it out from the centre with the Line Tool or you may select two tick marks and make a blend with a number of steps that give you a line where you want it, then expand the blend, and delete the intermediate line(s) afterwards), then use the Scissors Tool as in 2a), or just use the Scissors Tool by eye or based on a locked template underneath;
    3) If you wish to have a gap between the ends and the tick marks (as in the first OP image and post #5), you can:
    3a) Select each tick mark in question and in the Appearance palette flyout tick New Stroke, still in the Appearance palette drag the new stroke down beneath the original stroke, give it a Stroke Weight to cover the gap, and either:
    3a1) Give the copy stroke the colour of the background, or
    3a2) Expand Appearance, then select the copy stroke path and Object>Path>Outline Stroke to get a filled path and use that path as the guide to cut the (portion(s)) of the partial circle as in 2a).
    Did this have a sufficient unintelligibility to present a real challenge?
    Jul 31, 2013 6:06 AM   in reply to Jber505
    You are welcome, Jber, and nice to have it wound up.
    Normally, I prefer the ending -ness to -ility, but in this case the -ility word has quite a rhythm. I wonder which presents the greater challenge  in a drunk test, unintelligibleness or unintelligibility. It may also be hard to get the hyphens right in spelling them out.
