bind
Jul 13, 2012 2:45 PM
I have two text boxes
1.  First text box is defaulted to the curent date + 5 business days.
2.  When i pick the date from the second text box, I want the date in the fisrt text box = date in second text box + 5 business days.
The code i have below is currently working fine but the fist fidn't added 5 business days because i don't know how to add into it from txt2.
How can I accomplish it?
<!---cfm--->
<cfparam name="currentdate" default="#businessDaysAdd(now(),5))#">
<cfform name="fform">
   txt1: <cfinput type="datefield" value="#dateformat(current, "mm/dd/yyyy")#" name="txt1" bind="cfc:app.home.cfc.bu.getfinaldate({txt2@change})">
   txt2: <cfinput type="datefield" name="txt2" value="">
</cfform>
<!---cfc--->
</cfcomponent>
<cffunction name="getfinaldate" access="remote">
        <cfargument name="txt2">
         <cfreturn "#arguments.txt2#">
    </cffunction>
</cfcomponent>
    Jul 14, 2012 4:26 AM   in reply to kt03
    In your cfc, use parsedate to convert the text to a date, then use dateadd to add the five days and dateformat to convert it back to a string.
    Jul 15, 2012 2:45 AM   in reply to kt03
    Note you have a typo: 2 closing component tags. In any case, the following should work
    <!--- Set bindOnload to yes, making the bind to take effect the moment the page is loaded. --->
    <cfinput type="datefield"  name="txt1" bind="cfc:app.home.cfc.bu.getFinalDate({txt2})" bindOnload="yes">
    <cfinput type="datefield" name="txt2">
    </cfform>
    bu.cfc
    <cfcomponent>
    <cffunction name="getFinalDate" access="remote" returntype="string">
            <cfargument name="dateArg">
            <!--- If argument undefined or not a date, then default to date of today --->
            <cfif (not isDefined("arguments.dateArg")) or (not isDate(arguments.dateArg))>
                <cfset var dt = now()>
            <cfelse>
                <cfset var dt = parseDateTime(arguments.dateArg)>
            </cfif>
            <!--- Add 5 days--->
            <cfset var updatedDt = dateAdd("d",5,dt)>
            <!--- Format --->
            <cfset var formattedDt = dateformat(updatedDt, "mm/dd/yyyy")>
             <cfreturn formattedDt>
    </cffunction>
    </cfcomponent>
