MTS audio not working in PP CS6. Help??
Jul 14, 2012 11:46 AM
The most useful thread on this topic was locked before the problem was resolved, but I don't know why. Unfortunately I am a novice with Adobe Premiere, but PP is the tool I have to use in my project.
I have the Creative Cloud version of Adobe PP CS6. I am using a Sony HDR-XR260 camera. And like countless others I get no audio with my video clips when loaded into CS6.
I read all the discussions. I even tried the small clip of MTS that someone offered as a test. I could play that in PP CS6 with audio no problem.
But clips from my own camera have no audio. Doesn't matter how I load the clip (I have tried them all). The clips definitely have audio, becuse they work perfectly on WMP and other apps.
I tried renaming to M2TS... and everything else suggested. Was wondering if anyone has a FIX for this. I am desparate.
JM
    Jul 14, 2012 11:50 AM   in reply to jmcilroy
    JM,
    Just to make sure that it's not something very simple, lets' address two questions right off:
    Did you copy the full folder structure of your card to you HDD?
    Did you allow the Indexing and Conforming process to complete 100%
    Jul 14, 2012 12:15 PM   in reply to jmcilroy
    Well, you say "no folder structure" and then you say "folder names for the date" so it would seem you have a contradiction... is that "single MTS file representing the video clip" located inside the "folder names for the date"?
    What happens if you copy that "folder names for the date" from camera to hard drive, and then import into PPro from there?
    As far as indexing and conforming, clear you cache and then open your project again... and look at the lower right corner where there is a status display
    If you do not let the indexing and conforming process complete before trying to do anything, you will have problems
    Jul 14, 2012 12:25 PM   in reply to jmcilroy
    Upload a clip.  I'll test here.
    http://www.depositfiles.com/en/
    Jul 14, 2012 12:32 PM   in reply to jmcilroy
    Hmm... there is a known bug with CS6 and spanned clips, so it MAY be that you should send a report to Adobe so the product engineer(s) may check to see if the bug investigation needs to be expanded
    CS6 Bug AVCHD http://forums.adobe.com/thread/1004369?tstart=0
    -and http://forums.adobe.com/thread/1004369?start=0
    Bug report https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    Jul 14, 2012 12:41 PM   in reply to jmcilroy
    JM,
    Thanks for that info. As for Indexing and Conforming, this ARTICLE contains a lot of detail.
    Jul 14, 2012 2:54 PM   in reply to jmcilroy
    Did you get the file?
    Nope.
    "No such downlodable file or incorrect removal code."
