<code> tags no longer working
Jul 15, 2012 1:04 AM
I use html <code> tags sometimes when I want to instruct a user exactly what to type.
This used to be displayed in a monospace font like Courier New, with a white box around it.
No longer, now it just looks → like this
Also, code boxes used to display monospace fonts, but they do no longer either.  (They still have a white box around it.)
code line 1
  code line 2
    code line 3
XML and SQL code boxes still display monospace fonts, but Java and plain boxes don't.
I do not care so much about the code boxes, but the <code> tags should stand out.
  • John Hawkinson
    Jun 25, 2009
    Jul 15, 2012 6:37 PM   in reply to Pat Willener
    <code> is not a standard HTML tag. (BBcode has a [CODE] tag.)
    I'm pretty surprised to hear this ever worked! But it makes sense that Jive strips nonstandard tags. Doing so is good practice.
    You can use a properly css-formated <pre> tag...
    Edit: Fixed <code>/[CODE] renderings messed up by email interface.
  • John Hawkinson
    Jun 25, 2009
    Jul 15, 2012 6:36 PM   in reply to Pat Willener
    Oof. The email interface did horrible things to my message, not sure if it was intelligble (I've fixed it).
    And beyond that, I stand corrected! You're right, HTML does have a <CODE> tag. I was just wrong. It was even there in HTML2...
    Jul 15, 2012 8:15 PM   in reply to Pat Willener
    Have you tried using <pre>your code goes here ....</pre>?  I use something like this:
    <pre class="jive_text_macro jive_macro_code" jivemacro="code" ___default_attr="plain"><p><code class="jive-code">code line 1
      code line 2
        code line 3
    <br /></code></p></pre>
    To get like this:
    code line 1
      code line 2
        code line 3
    Hope this helps.
    Jul 19, 2012 9:31 AM   in reply to Pat Willener
    Thanks, Pat! We've logged this bug.
    I'm new to bug-fixing process at Adobe, so I'm not sure how long it will take for the engineers to get through the log.
