Spark is overriding MX tab order... Probably something simple.
Jul 16, 2012 9:22 AM
I have a large project with some legacy code which is therefore using a mish-mash of spark and mx components.
This is fine for the most part, they work side by side with only a few niggles like remembering the difference between removeChild and removeElement etc.
BUT...
I have a complex, dynamically generated form that I should be able to tab between fields of built in mx and _EVERY_ time I tab, no matter what I do, it takes me _OUT_ of the complex generated form and plonks me in the first Spark control it finds - generally the home button at top left.
This, I hasten to add, is really not a good user experience!
I've tried all the obvious things (tab enabling, tab index etc) but Spark just seems to override it all, as if to say "why would that dirty _old_ mx component want focus? it wouldn't even know what to do with it?"
So, please, does anybody have any useful pointers on integrating mx components into the tab focus hierarchy?
G
    Jul 17, 2012 9:14 AM   in reply to Gaius Coffey
    Did a little test and not seeing the out of order tab behavior. I'm wondering if it might have something to do with your container hierarchy.
    Here's some sample code that worked for me using AIR and the Flash Player:
    <pre class="jive_text_macro jive_macro_code" jivemacro="code" ___default_attr="html"><p><mx:Button label="mx Btn Start" y="0" />
    <s:VGroup y="30">
    <s:Button label="Spark Btn 1" />
    <s:Button label="Spark Btn 2" />
    <mx:Canvas>
    <mx:TextInput y="10" text="mx TI 1" />
    <mx:TextInput y="38" text="mx TI 2" />
    <mx:Button label="mx Btn Submit" y="64" />
    </mx:Canvas>
    <s:TextInput prompt="Spark TI 1"/>
    </s:VGroup> </p></pre>
    Good luck!
    b
    Jul 17, 2012 9:20 AM   in reply to Brandon Ellis
    wow. that code insert is heinous!
