Adobe Audition CS6 (5.0.1) update patch released
Jul 20, 2012 12:19 PM
UPDATE:  A new 5.0.1 update build has been made available as of July 20, 2012, due to an issue discovered in the Dynamics Processing effect.  If you previously updated Adobe Audition CS6, please visit the links below and install the new update.  This update is not available via Adobe Update Manager and must be downloaded via the website.
Today we released an update to address several bugs in Audition CS6. Many were minor workflow issues, but a few could cause Audition to crash under certain circumstances.
bugs fixed in Adobe Audition CS6 5.0.1 update:
  • APE files with metadata inserted by other editors cause Audition to crash (Windows)
  • If previous session directory no longer exists, Audition leaves the Folder Location field empty
  • Multitrack fades no longer respect the fade type preference.  (Worked in CS5.5)
  • Audition may crash when users choose to create unique copies of selected MT regions
  • Playback stutters when creating a unique copy of a clip while right-click dragging
  • Channel Mix settings not honored on export when not exposed in dialog
  • EUCON Soft Key set contains keys that do nothing
  • Session Tempo broken on systems using commas instead of decimal points
  • Bounce to New Track > Selected Track bounces AFTER passing through track output
  • If a favorite was recorded on subset of channels, the favorite will fail if those channels are disabled
  • Sending a stereo bus side-chained to a mono track may crash the application
  • UAD-2 plug-ins missing from Windows Effects menu
  • Audition may crash on launch when CoolType encounters certain installed fonts (Mac)
