How do I pass a string variable from a movieclip timeline to a url request inside of a class?
Jul 17, 2012 9:22 PM
Tags: #string #actionscript3 #urlrequest
Hello,
I've coded an audio player class I'd like to be able to reuse throughout my project to play a different sound in each movieclip. The audio player works great and the sound loads when I request the url from within the class but I'm having trouble requesting the url coded on the parent movieclip's timeline.
I have an instance of a movieclip named musicPlayer in 4 different parent movieclips that is linked to a class named MusicPlayer which contains my audio player code.
To test, in one of the parent movieclips, I've placed the following code to set the url path to a string variable:
var mp3url = "tuba.mp3";
Then, in my class I've declared the same variable as a string:
public var mp3url:String;
and tried passing it to my url request:
mp3File.load(new URLRequest(mp3url));
I'm then receiving an error: "1151: A conflict exists with definition mp3url in namespace internal."
As mentioned above, the sound is loaded perfectly when I set the url path to a string variable within my class like so:
public var mp3url:String = "tuba.mp3";
Thank you in advance!
  • kglad
    Jul 21, 2002
    Jul 17, 2012 9:42 PM   in reply to DanEdmonds
    use a function to pass that variable or you'll have a timing issue:
    in your class:
    private function urlF(urlS:String):void{
    // declare mp3url in your class
    mp3url=urlS;
    // you can now use mp3url
    // on your timeline:
    varF("tuba.mp3");
  • kglad
    Jul 21, 2002
    Jul 18, 2012 6:25 AM   in reply to DanEdmonds
    you're welcome.
  • kglad
    Jul 21, 2002
    Oct 1, 2012 9:53 AM   in reply to DanEdmonds
    use:
    var mInfo:MoreInfo=new MoreInfo("http://wvsokids.org/the-music/elements-of-music/melody.html");
  • kglad
    Jul 21, 2002
    Oct 1, 2012 12:42 PM   in reply to DanEdmonds
    it creates a MoreInfo instance which is how your MoreInfo class is designed to be used.
    the line of code i suggested would not trigger that error if used with the MoreInfo class you showed.
