• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
iOS application dies - suspect a memory issue
New Here ,
Jul 18, 2012 Jul 18, 2012
I have a reasonably large AIR application developed in CS6 using AIR 3.3 (I tried 3.2 as well). Works fine on my computer but when I upload it to an iPhone the application tries to start but then dies and returns to the apple home screen.
The application contains about 12 screens each of which contain many (50+) variables / movie clips etc. Tried to debug it using the external debugger but no errors appear in CS6. When I limit the number of screens I create to e.g. 9 screens only it starts to work again. Which 3 I disable is totally irrelevant (first  or last 3 screens) - when I get down to 9 screens all is well.
I don't really know where to start looking for a solution to this. Anyone has any suggestions?
Leon
TOPICS
Development
Views
978
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Does closing all the background apps make any difference?
Votes
Translate
Translate
Report
Report
New Here ,
Unfortunately not. Tried rebooting the phone frequently and makes no difference.
Votes
Translate
Translate
Report
Report
Participant ,
Using any ANEs? The number of slides could be a red herring.
Have you looked at the Console pane in the iPhone Config Utility while running the app?
Votes
Translate
Translate
Report
Report
Engaged ,
9 or less works, 10 or more does not... show us your code.
it could be a problem with a number of things, but is probably an easy fix:
[for loops, naming conventions, missing objects, declaration of an object, etc...]
Votes
Translate
Translate
Report
Report
New Here ,
Jul 19, 2012 Jul 19, 2012
Thanks for your replies - in answer to your questions:
  • "Using ANE's?": yes about 7 of them....
  • "Looked a the console pane?" That was a very interesting one. I never knew I could do that and it seems like a great tool. I just posted another question about this as it would safe me weeks of works if I could actually put my own stuff (from my application) on this console. Is there a way of doing that?
  • "Show us your code". - It really is too big to post here but I refactored my code so it uses less screens and it seems to be working now so for the time being - I'm OK
Leon
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Yikes. Based on my experience with native extensions, at least one of those ANEs is almost certainly the cause of the crash-on-startup problem.
Take a look at the iTunes' CrashReporter folder on your Mac or PC. Most of the information in crash logs is not helpful, but you might get a better idea of what's causing the crashes.
As for sending trace statements to the the Console pane -- it would probably require another ANE. I would stick to publishing for device debugging. By adding breakpoints and trace statements to your startup code, you should eventually find the code that's causing the crashes.
Votes
Translate
Translate
Report
Report
