for in loop reverse order
Jul 18, 2012 7:51 PM
Tags: #for #as3 #in #loop #order
I'm trying to find a way to reverse the order that the for...in loop goes in, or reverse the index of variables on an object.
Example:
var o:Object = new Object();
o["a"] = {};
o["b"] = {};
for (var s:String in o)
    trace(s);
this would output:
b
a
however, I need it to output:
a
b
The reason I need to do this is because I'm adding elements to the object as it loops, and I need it to loop through the elements in order rather than the elements that were just added.
In the actual script the for...in loop is nested in a while(true) infinite loop that breaks from within the for...in loop.
I've already tried using setChildIndex, but it doesn't work due to the children being arrays.
  • kglad
    Jul 21, 2002
    Jul 18, 2012 10:54 PM   in reply to Kyle517
    an object is an unordered collection of keys and values. it makes no sense to try and control the ordering of keys/values in an object.
    you should use an array (or 2d array) if ordering is important.
  • kglad
    Jul 21, 2002
    Jul 19, 2012 6:39 PM   in reply to Kyle517
    again:
