boby128
How to use OCR silently ?
Jul 19, 2012 7:16 AM
Tags: #acrobat #pdf #ocr #sdk
Hello,
I have acrobat standard 9 installed on my computer, and I would like if I can use Acrobat SDK
to create a program (in cpp) to call silently the OCR (without any dialog or popup) on my pdf file.
    Jul 19, 2012 8:30 AM   in reply to boby128
    You will need to write a custom plugin (in C/C++) to Acrobat to invoke the OCR and you could then call that from you separate application if you wish.
    Jul 20, 2012 3:00 AM   in reply to boby128
    You can only use AVCommand from within a plug-in.
    Your program would have to
    * start Acrobat ,with your plug-in installed
    * have your plug-in monitor for an external event in a timer proc (this isn't an Acrobat event)
    * have the program trigger the event
    * have the plug-in work and send a message back to your program
    Note that this can only happen on your workstation, it isn't for server use.
    Jul 20, 2012 4:15 AM   in reply to boby128
    The Acrobat SDK is about automating Acrobat – so YES, it MUST be running.
    If this is happening on your workstation, in an interactive fashion, why does it matter if Acrobat is visible?
    Jul 20, 2012 7:19 AM   in reply to boby128
    Well, some SDKs will avoid that. For example the Windows SDK - you can run some neat programs, but you still have to run Windows!  The Acrobat SDK is a tool for automating the visual tool Acrobat; not a back end engine for high powered processing. (Adobe have various pricy tools in that territory, but not for OCR).
