Automatically resize two text bars borders to each other
Jul 19, 2012 9:51 AM
Tags: #problem #script #text #3.0 #action #actionscript #as3.0 #actionscript3 #function
Gotta another action script puzzle im trying to figure out.
My program has two rows of text, stacked on top of each other.
they adjust to each other, to match when text is entered so it stays a nice square.
the problem is I cant seem to get the text bars on top to resize to the text bars on bottom.
Worth mentioning, it works the other way around, the bottom text resizes to the top text.
any help would be apperciated.
//here is my code
addEventListener(Event.ENTER_FRAME,strehrows, false, 0, true);
function strehrows(event:Event)
          if (MovieClip(parent.parent).textSelect == textArray100["pair1"],false,0,true)
                    textArray100["pair1"].autoSize = TextFieldAutoSize.LEFT;
                    textArray100["pair13"].autoSize = TextFieldAutoSize.NONE;
                    textArray100["pair13"].width = textArray100["pair1"].width;
          }else
          if (MovieClip(parent.parent).textSelect == textArray100["pair13"],false,0,true)
                    textArray100["pair13"].autoSize = TextFieldAutoSize.RIGHT;
                    textArray100["pair1"].autoSize = TextFieldAutoSize.NONE;
                    textArray100["pair1"].width = textArray100["pair13"].width;
  • kglad
    Jul 21, 2002
    Jul 19, 2012 12:17 PM   in reply to tropicanaclock
    if you're not seeing any error messages, what is:
    and what is
  • kglad
    Jul 21, 2002
    Jul 19, 2012 12:42 PM   in reply to tropicanaclock
    what's all that false,0,true stuff in your if-statement.  those look like event listener parameters, not something that belongs in an if-statement.
  • kglad
    Jul 21, 2002
    Jul 19, 2012 4:29 PM   in reply to tropicanaclock
    copy and paste the code you're using.  i can't debug code that's related but not the same as the code you use.
    also, use the trace() function to check the values that you're checking and copy and paste that output too.
    for example,
    trace(MovieClip(parent.parent).textSelect.name,textArray100["pair1"].n ame,textArray100["pair13"].name);
              if (MovieClip(parent.parent).textSelect == textArray100["pair1"])
              }else
