Crop - Front image dimensions
Jul 20, 2012 6:54 AM
Tags: #cs6 #dimensions #crop_tool #crop_tool_preferences #crop_problem #front_image
I have a little problem with the cropping tool in the new CS6 version.
In CS5 I had the oppotunity to choose "Front image" and the crop tool would copy the dimensions from the chosen image.
Now I made a mistake and cropped a picture with the wrong dimensions. Ususally I choose "original ratio", but this time I forgot. Then normally in CS5 I just choose one of the other pictures in my workspace (with the original dimensions) and hit the "front image" button, and then I got back the the picture I cropped in the wrong dimenions, and now I could easily crop it with the right dimensions.
I found another discussion in the forum that answered exactly this question, and it said "Try pressing 'R' in crop mode. It will open Crop Image Size & Resolution window, where you can choose Source: Custom, Front Image, etc."
But when I press "R" in the crop mode nothing like that comes up. Instead the oppotunity to rotate comes up... :-( Not what I was looking for...
What to do?
I work on a PC
Best regards
Hanne
    Jul 20, 2012 7:04 AM   in reply to HPK_fotograf
    Have you dragged out a Cropping Area before hitting R?
    Jul 21, 2012 1:41 AM   in reply to HPK_fotograf
    Well, quite frankly it seems in CS6 not everything that has been changed has been changed in such a way as to make its use more efficient.
    For example changing Path Operations now is a two-click (or click-drag-release) task when it was a one-click-task in CS5.
    Jul 21, 2012 2:20 AM   in reply to HPK_fotograf
    With the crop tool selected you can right click on the image to get a pop-up menu.
    I guess using the R shortcut is easier because you don't have switch images.
