How to auto crop an image?
Jul 20, 2012 2:13 PM
How do you auto crop an uploaded image?  I see that there are workflow steps and it seems there might be a couple that can create new assets, but where is the documentation for that?
Also, how do you set the auto crop aspect ratio for the html4image widget?
    Jul 22, 2012 9:19 PM   in reply to stewa52
    You can see example at the existing image component by adding more aspect ratios using the "cropConfig" node. Please reference one under - "/libs/cq/packaging/components/pack/definition/dialog/items/tabs/item s/tab3/cropConfig". In this manner, you can add in more option and specify the required height/width.
    Jul 23, 2012 6:14 PM   in reply to stewa52
    I think you can modify the workflow model to apply aspect ratio & some custamization to apply later. I will do little research to see if it exists in cq 5.5 & to confirm if it is lacking documentation for this feature.
    Jul 26, 2012 2:28 AM   in reply to stewa52
    Creating a different renditions (or different size images) at the time of uploading dam asset can be achieved by modifying the
    existing DAM workflow.
    Follow the given steps to modify DAM workflow.
    1. Go to workflow console
           http://localhost:4502/libs/cq/workflow/content/console.html
    1. Go to Models Tab
    2. Find "DAM Update Asset" workflow and edit the workflow It will take you to the detailed page.
    3. Find "Thumbnail creation" process step, Double click on it
    4. A dialog will open; Go to Second Tab (Process). There you will find "Arguments" for aspect ratios of images
    5. Here you can specify Aspect Ratio at which you want to auto crop the dam assest while uploading.
    6. Click Save.
    These steps are same for both the CQ version 5.4 and 5.5              .
    Brijesh
