I feel so stupid when I can't understand something so easy on a linux... I'm sure it's an easy thing because no one has mentioned anything about it when I search the web!
also asked on http://stackoverflow.com/questions/11590474/bat-equivalent-on-linux
I'm new to linux ubuntu and I need to be able to package my air android app on my ubuntu server. if it was a windows server, I could easilly create a .bat and package my apk like below:
<pre>
@echo off
set PAUSE_ERRORS=0
:user_configuration
:: Path to Flex SDK
set FLEX_SDK=C:\sdk\flex_sdk_4.5.1.21328
:: Path to Android SDK
set ANDROID_SDK=C:\sdk\android
:validation
if not exist "%FLEX_SDK%\bin" goto flexsdk
if not exist "%ANDROID_SDK%\platform-tools" goto androidsdk
goto succeed
:validation
goto succeed
:flexsdk
echo.
echo ERROR: incorrect path to Flex SDK
echo.
if %PAUSE_ERRORS%==1 pause
exit
:androidsdk
echo.
echo ERROR: incorrect path to Android SDK in 'bat\SetupSDK.bat'
echo.
exit
:succeed
set PATH=%PATH%;%FLEX_SDK%\bin
set PATH=%PATH%;%ANDROID_SDK%\platform-tools
:: Android packaging
set AND_CERT_NAME="PeymanApp"
set AND_CERT_PASS=fd
set AND_CERT_FILE=cert\SampleApp.p12
set AND_ICONS=icons/android
set AND_SIGNING_OPTIONS=-storetype pkcs12 -keystore "%AND_CERT_FILE%" -storepass %AND_CERT_PASS%
:: Application descriptor
set APP_XML=application.xml
:: Files to package
set APP_DIR=bin
set FILE_OR_DIR=-C %APP_DIR% .
:: Your application ID (must match <id> of Application descriptor)
set APP_ID=air.com.doitflash.SampleApp
:: Output packages
set DIST_PATH=dist
set DIST_NAME=PeymanApp
:validation
%SystemRoot%\System32\find /C "<id>%APP_ID%</id>" "%APP_XML%" > NUL
if errorlevel 1 goto badid
goto end_validation
:badid
echo.
echo ERROR: Application ID (APP_ID) does NOT match Application descriptor '%APP_XML%' (id)
echo.
:end_validation
set TARGET=
set PLATFORM=android
::call bat\Packager.bat
if "%PLATFORM%"=="android" goto android-config
:android-config
set CERT_FILE=%AND_CERT_FILE%
set SIGNING_OPTIONS=%AND_SIGNING_OPTIONS%
set ICONS=%AND_ICONS%
set DIST_EXT=apk
set TYPE=apk
goto start
:start
if not exist "%CERT_FILE%" goto certificate
:: Output file
set FILE_OR_DIR=%FILE_OR_DIR% -C "%ICONS%" .
if not exist "%DIST_PATH%" md "%DIST_PATH%"
set OUTPUT=%DIST_PATH%\%DIST_NAME%%TARGET%.%DIST_EXT%
:: Package
echo true
echo.
call adt -package -target %TYPE%%TARGET% %OPTIONS% %SIGNING_OPTIONS% "%OUTPUT%" "%APP_XML%" %FILE_OR_DIR% -extdir lib/
echo.
if errorlevel 1 goto failed
goto end
:certificate
echo Certificate not found: %CERT_FILE%
echo.
exit
:failed
echo APK setup creation FAILED.
exit
:end
</pre>
but I don't know how to create a similar bash file in linux to take care of that... (I know that adt.exe and adb.exe work on windows and I have their linux equivelent already installed) I just donno how to create a bash file to package the whole thing!
for some reasons, I don't want to use eclipse or other tools to package for me, I need to do it manually using just one bash file in mu ubuntu server...
thanks...
North America
Asia Pacific
