Scrolling very jerky in CS6 on Mac
Jul 21, 2012 7:05 PM
Tags: #scrolling #bridge
I'm running Bridge CS6 ver. 5.0.0.399 on a MBP with OS X 10.7.4
In earlier versions of Bridge (before CS6) when scrolling in the Folders Panel browser with either a magic mouse or the trackpad (not using the scroll bars) the scrolling was very smoth, moving a line at a time. Now it jumps a seemingly randomly number of lines, making it nearly impossible to accurately scroll to where you need to go without using the scroll bars. Scrolling of actual images within the Content Panel works great. This really needs to be fixed, unless there's an option I missed?
Thanks.
    Jul 22, 2012 10:35 AM   in reply to wee_ag
    Not a mac guy, but this function should be governed by the OS and mouse software.  Might try a wired mouse and see it the problem is solved.
    Jul 22, 2012 7:11 PM   in reply to wee_ag
    With computers who knows.
    I have seen several posts, at least in windows, were a wireless mouse can cause muliple problems, and work fine in other applications.  So maybe the mouse driver has conflicts with Bridge.  Only what I know to check that is to try a wrired mouse as it is the simplist.
    Jul 24, 2012 8:45 AM   in reply to wee_ag
    anyone figure out if it's the wireless mouse or not!?
    Jul 27, 2012 5:44 PM   in reply to MiahScharpe
    No still jerky/fast with wired mouse as well.
    Jul 27, 2012 7:27 PM   in reply to wee_ag
    Was hoping a Mac guy would peek in with an opinion.
    If you go back to a previous version of Bridge when scrolling was smooth, is it still that way?  Or has that changed also?
    Is 10.7.4 called Mountain Lion?  There have been a number of posts here and on Photoshop forum of conficts in how program is running.
    Jul 28, 2012 3:45 AM   in reply to Curt Y
    Curt Y wrote:
    Was hoping a Mac guy would peek in with an opinion…
    I had abstained from jumping in because I don't use either a Magic Mouse nor the MacBook's track pad, nor am I running Lion.  I use a wired Apple keyboard and Apple mouse.  No jumpiness here.
    Now that AllisonGail reports the same issue with a wire mouse, I'm in a position to report that I don't see the scrolling issue, but then I'm on Snow Leopard 10.6.8.
    Curt Y wrote:…
    Is 10.7.4 called Mountain Lion?…
    Nope, 10.7.x is LionMountain Lion is 10.8.x and it was just released two days ago, so it's at 10.8.0.
    If you disregard the number 10 in front of the first dot. Panther was OS X 3, Tiger was 4, Leopard was 5, Snow Leopard was 6, Lion was 7 and Mountain Lion is 8 (released July 25 of this year).  The best three are highlighted in color.
    The first three, Cheetah (10.0), Puma (10.1) and Jaguar (10.2) were plain bad.  I'm not getting anywhere near either of the lions either.
    As far as functionality, stability and speed, Tiger is the best OS X for a Power Mac and Snow Leopard the best for an Intel Mac.
    Now the names of all Big Cats have been used, even in the more expanded definition of the term.
    EDITNow the names of all Big Cats have been used…
    _
    Message was edited by: station_two
    Jul 28, 2012 1:39 AM   in reply to wee_ag
    Here are some details on my five-year-old Mac lapbook system, on which I do not see the scrolling jumpiness issue:
    Name: MacBook (late 2006), manufactured in May of 2007
    Model: mb_late_06
    Model Identifier:          MacBook2,1
    Hardware:
    Hardware Overview:
      Model Name:          MacBook
      Processor Name:          Intel Core 2 Duo
      Processor Speed:          2 GHz
      Number Of Processors:          1
      Total Number Of Cores:          2
      L2 Cache:          4 MB
      Memory:          4 GB
      Bus Speed:          667 MHz
      Boot ROM Version:          MB21.00A5.B07
      SMC Version (system):          1.13f3
      Serial Number (system):          W87180XQWGQ
      Hardware UUID:          00000000-0000-1000-8000-001B631BC56F
      Sudden Motion Sensor:
      State:          Enabled
    Graphics/Displays:
    Intel GMA 950:
      Chipset Model:          GMA 950
      Type:          GPU
      Bus:          Built-In
      VRAM (Total):          64 MB of Shared System Memory
      Vendor:          Intel (0x8086)
      Device ID:          0x27a2
      Revision ID:          0x0003
      Displays:
    Color LCD:
      Resolution:          1280 x 800
      Pixel Depth:          32-Bit Color (ARGB8888)
      Mirror:          Off
      Mirror Status:          Hardware Mirror *OFF (CLAMSHELL MODE)
      Online:          Yes
      Built-In:          Yes
    electr22b4:
      Resolution:          1280 x 1024 @ 85 Hz
      Main Display: * ACTING AS SECONDARY DISPLAY
      Driven by DisplayLink / USB Adapter (see below)
      Online:          Yes
      Rotation:          Supported
    DPro 2070SB:
      Depth:          32-bit Color
      Core Image:          Supported
      Main Display: * Yes
      Driven by MacBook's internal Graphics Card
      Mirror:          Off
      Online:          Yes
      Quartz Extreme:      Supported
    USB:  USB to DVI/HDMI/VGA Display Adapter
    Driving the Secondary External Monitor through DisplayLink driver
    External FireWire 400 hard drive as Photoshop primary scratch disk.
    Serial ATA:
    Hitachi HTS541616J9SA00:
      Capacity:          160.04 GB (160,041,885,696 bytes)
      Model:          Hitachi HTS541616J9SA00
      Revision:          SB4AC7CP
      Serial Number:                SB2404SJJ69X3E
      Native Command Queuing:          Yes
      Queue Depth:          32
      Removable Media:          No
      Detachable Drive:          No
      BSD Name:          disk0
      Medium Type:          Rotational
      Partition Map Type:          GPT (GUID Partition Table)
      S.M.A.R.T. status:          Verified
      Volumes:
      Capacity:          209.7 MB (209,715,200 bytes)
      Writable:          Yes
      BSD Name:          disk0s1
    MacBook HD:
      Capacity:          159.7 GB (159,697,911,808 bytes)
      Available:          128.88 GB (128,880,795,648 bytes)
      Writable:          Yes
      File System:          Journaled HFS+
      BSD Name:          disk0s2
      Mount Point:          /
    USB Bus:
      Host Controller Location:          Built-in USB
      Host Controller Driver:          AppleUSBUHCI
      PCI Device ID:          0x27c8
      PCI Revision ID:          0x0002
      PCI Vendor ID:          0x8086
      Bus Number:          0x1d
    Hub in Apple Pro Keyboard:
      Product ID:          0x1003
      Vendor ID:          0x05ac  (Apple Inc.)
      Version:           4.10
      Speed:          Up to 12 Mb/sec
      Manufacturer:          Mitsumi Electric
      Location ID:          0x1d100000 / 2
      Current Available (mA):          500
      Current Required (mA):          50
    Apple Optical USB Mouse:
      Product ID:          0x0306
      Version:           1.01
      Speed:          Up to 1.5 Mb/sec
      Manufacturer:          Fujitsu Component
      Location ID:          0x1d110000 / 5
      Current Available (mA):          100
      Current Required (mA):          100
    Apple Pro Keyboard:
      Product ID:          0x020b
      Version:           4.10
      Location ID:          0x1d130000 / 4
      Current Available (mA):          250
    Apple Internal Keyboard / Trackpad:
      Product ID:          0x021a
      Version:           0.18
      Manufacturer:          Apple Computer
      Location ID:          0x1d200000 / 3
      Current Required (mA):          40
    USB Bus:
      PCI Device ID:          0x27c9
      Bus Number:          0x3d
    USB Bus:
      PCI Device ID:          0x27ca
      Bus Number:          0x5d
    IR Receiver:
      Product ID:          0x8240
      Version:           1.10
      Manufacturer:          Apple Computer, Inc.
      Location ID:          0x5d200000 / 2
    USB Bus:
      PCI Device ID:          0x27cb
      Bus Number:          0x7d
    Bluetooth USB Host Controller:
      Product ID:          0x8205
      Version:          19.65
      Manufacturer:          Apple Inc.
      Location ID:          0x7d100000 / 2
      Current Required (mA):          0
    Photoshop 13.0 ("CS6")
    _
    Aug 1, 2012 12:57 PM   in reply to station_two
    Read this article, i have problems specially with audition and premiere but it seems to be adobe who have the problems and not Apple.
    http://www.pulptopixels.com/2011/05/11/make-your-magic-mouse-play-nice -with-adobe-apps/
    Try other apps, i can scroll px by px in opera but not in photoshop.
    i will try this
    http://www.instructables.com/id/Computer-scroll-wheel-bearings-version /
    but if you have money try this
    http://retail.contourdesign.com/?/products/5
