• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
What causes an imported SWF to flash between slides with black background?
New Here ,
Jul 22, 2012 Jul 22, 2012
What causes an imported SWF to flash between slides with black background?  SWF is published in AS2 and I am using the latest version of 7.0 Adobe Presenter
TOPICS
Presenter
Views
812
Translate
Translate
Report
Report
Community guidelines
community guidelines
New Here ,
By the way, it flashes with a black background.
Votes
Translate
Translate
Report
Report
Engaged ,
Does this happen with a specific SWF file or any imported SWF?
Can you tell us the build of Presenter you are working on? Once you go to Presenter tab inside PowerPoint, look for "Help" and click "About Presenter".
kindly tell us the build number mentioned there.
If the issue is happening with a specific file, please share the SWF ifle with us at mvlele@adobe.com
Regards,
Mukul
Votes
Translate
Translate
Report
Report
LEGEND ,
Jul 23, 2012 Jul 23, 2012
LATEST
If you are using 7.0.6 or older, then you should be using an AS2 SWF, as you are, and I would reccomend working with Mukul to find the resolution. If you are using 7.0.7, then the SWF is likely the issue as this version uses AS3.
Votes
Translate
Translate
Report
Report
Resources
Help resources
