Noel Carboni 23,526 posts
Dec 23, 2006
Issues with Lighting Effects
Jul 23, 2012 7:54 PM
Filter - Render - Lighting Effects seems to be somewhat less than perfectly functional for me.
Unlike another recent poster, I'm seeing the controls okay, but they don't actually seem to work properly.  Worse, I can reliably produce a crash.
I have an ATI Radeon HD 5670 and Catalyst 12.6 (latest released) drivers for Windows 7 x64, Advanced mode GPU operation.  My detailed system info can be found here:  Link
Chances are this is a display driver issue, but I want Adobe to know about it.
Here's what I see...
For testing I create a middle-gray square document, 8 bits/channel, sRGB, then start the Lighting Effects filter on it:
If I toggle the preview setting off and on a number of times, this happens:
This is reproducible, though it sometimes takes more or less Preview toogles.  Here is the pertinent information from several such Photoshop crashes:
Next I am going to try Normal and Basic mode to see if they make any difference with this problem.  I'll follow up here.
-Noel
    Jul 24, 2012 1:21 AM   in reply to Noel Carboni
    Hi Noel,
    Thanks for reporting this here. I'll see if I can reproduce with my 5870 card first, and then try a 5670 if needed. Do you have anything else set in the Catalyst Control panels or is it a default install?
    regards,
    steve
    Jul 24, 2012 9:01 AM   in reply to Noel Carboni
    Noel, followed your example and no crashes on my system (Intel 4000 card with latest production drivers) but horribly slow, probably the slowest filter I have ever tried - Basically unusable.....
    Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
    Operating System: Windows 7 64-bit
    Version: 6.1 Service Pack 1
    System architecture: Intel CPU Family:6, Model:10, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
    Physical processor count: 4
    Logical processor count: 8
    Processor speed: 3392 MHz
    Built-in memory: 16272 MB
    Free memory: 3469 MB
    Memory available to Photoshop: 14657 MB
    Memory used by Photoshop: 60 %
    Image tile size: 128K
    Image cache levels: 4
    OpenGL Drawing: Enabled.
    OpenGL Drawing Mode: Advanced
    OpenGL Allow Normal Mode: True.
    OpenGL Allow Advanced Mode: True.
    OpenGL Allow Old GPUs: Not Detected.
    Video Card Vendor: Intel
    Video Card Renderer: Intel(R) HD Graphics 4000
    Display: 1
    Display Bounds:=  top: 0, left: 0, bottom: 1080, right: 1920
    Video Card Number: 1
    Video Card: Intel(R) HD Graphics 4000
    OpenCL Version:
    Driver Version: 8.15.10.2696
    Driver Date: 20120319000000.000000-000
    Video Card Driver: igdumd64.dll,igd10umd64.dll,igd10umd64.dll,igdumd32,igd10umd32,igd10u md32
    Video Mode: 1920 x 1080 x 4294967296 colors
    Video Card Caption: Intel(R) HD Graphics 4000
    Video Card Memory: 2112 MB
    Video Rect Texture Size: 8192
    Serial number: 91198812271284256640
    Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
    Temporary file path: C:\Users\MIKEPH~1\AppData\Local\Temp\
    Photoshop scratch has async I/O enabled
    Scratch volume(s):
      C:\, 745.2G, 652.1G free
      D:\, 1.07T, 1.02T free
      J:\, 931.5G, 917.7G free
    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
    Additional Plug-ins folder: not set
    Installed components:
       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
       ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
       adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
       AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
       AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
       AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
       AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
       AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
       AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
       AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
       adobe_caps.dll   Adobe CAPS   6,0,29,0
       AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
       ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
       aif_core.dll   AIF   3.0   62.490293
       aif_ocl.dll   AIF   3.0   62.490293
       aif_ogl.dll   AIF   3.0   62.490293
       amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
       ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
       AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
       AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
       Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
       BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
       boost_date_time.dll   DVA Product   6.0.0
       boost_signals.dll   DVA Product   6.0.0
       boost_system.dll   DVA Product   6.0.0
       boost_threads.dll   DVA Product   6.0.0
       cg.dll   NVIDIA Cg Runtime   3.0.00007
       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
       CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
       CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
       data_flow.dll   AIF   3.0   62.490293
       dvaaudiodevice.dll   DVA Product   6.0.0
       dvacore.dll   DVA Product   6.0.0
       dvamarshal.dll   DVA Product   6.0.0
       dvamediatypes.dll   DVA Product   6.0.0
       dvaplayer.dll   DVA Product   6.0.0
       dvatransport.dll   DVA Product   6.0.0
       dvaunittesting.dll   DVA Product   6.0.0
       dynamiclink.dll   DVA Product   6.0.0
       ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
       FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
       filter_graph.dll   AIF   3.0   62.490293
       hydra_filters.dll   AIF   3.0   62.490293
       icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
       image_compiler.dll   AIF   3.0   62.490293
       image_flow.dll   AIF   3.0   62.490293
       image_runtime.dll   AIF   3.0   62.490293
       JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
       LogSession.dll   LogSession   2.1.2.1640
       mediacoreif.dll   DVA Product   6.0.0
       MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
       msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
       msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
       msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
       pdfsettings.dll   Adobe PDFSettings   1.04
       Photoshop.dll   Adobe Photoshop CS6   CS6
       Plugin.dll   Adobe Photoshop CS6   CS6
       PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
       PSArt.dll   Adobe Photoshop CS6   CS6
       PSViews.dll   Adobe Photoshop CS6   CS6
       SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
       ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
       tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
       TfFontMgr.dll   FontMgr   9.3.0.113
       TfKernel.dll   Kernel   9.3.0.113
       TFKGEOM.dll   Kernel Geom   9.3.0.113
       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
       updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
       WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
       wu3d.dll   U3D Writer   9.3.0.113
    Required plug-ins:
       Accented Edges 13.0
       Adaptive Wide Angle 13.0
       ADM 3.11x01
       Angled Strokes 13.0
       Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Bas Relief 13.0
       BMP 13.0
       Chalk & Charcoal 13.0
       Charcoal 13.0
       Chrome 13.0
       Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Color Halftone 13.0
       Colored Pencil 13.0
       CompuServe GIF 13.0
       Conté Crayon 13.0
       Craquelure 13.0
       Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Crop and Straighten Photos Filter 13.0
       Crosshatch 13.0
       Crystallize 13.0
       Cutout 13.0
       Dark Strokes 13.0
       De-Interlace 13.0
       Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Diffuse Glow 13.0
       Displace 13.0
       Dry Brush 13.0
       Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Embed Watermark 4.0
       Extrude 13.0
       FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Fibers 13.0
       Film Grain 13.0
       Filter Gallery 13.0
       Fresco 13.0
       Glass 13.0
       Glowing Edges 13.0
       Grain 13.0
       Graphic Pen 13.0
       Halftone Pattern 13.0
       HDRMergeUI 13.0
       IFF Format 13.0
       Ink Outlines 13.0
       JPEG 2000 13.0
       Lens Blur 13.0
       Lens Correction 13.0
       Lens Flare 13.0
       Liquify 13.0
       Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Mezzotint 13.0
       MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Mosaic Tiles 13.0
       Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Neon Glow 13.0
       Note Paper 13.0
       NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Ocean Ripple 13.0
       Oil Paint 13.0
       OpenEXR 13.0
       Paint Daubs 13.0
       Palette Knife 13.0
       Patchwork 13.0
       Paths to Illustrator 13.0
       PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Photocopy 13.0
       Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Pinch 13.0
       Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Plaster 13.0
       Plastic Wrap 13.0
       PNG 13.0
       Pointillize 13.0
       Polar Coordinates 13.0
       Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Poster Edges 13.0
       Radial Blur 13.0
       Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Read Watermark 4.0
       Reticulation 13.0
       Ripple 13.0
       Rough Pastels 13.0
       Save for Web 13.0
       ScriptingSupport 13.0
       Shear 13.0
       Silver Efex Pro 2 2,004
       Smart Blur 13.0
       Smudge Stick 13.0
       Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Spatter 13.0
       Spherize 13.0
       Sponge 13.0
       Sprayed Strokes 13.0
       Stained Glass 13.0
       Stamp 13.0
       Sumi-e 13.0
       Targa 13.0
       Texturizer 13.0
       Tiles 13.0
       Torn Edges 13.0
       Twirl 13.0
       Underpainting 13.0
       Vanishing Point 13.0
       Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Water Paper 13.0
       Watercolor 13.0
       Wave 13.0
       WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       Wind 13.0
       Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
       ZigZag 13.0
    Optional and third party plug-ins:
       Camera Raw 7.1
       HDR Efex Pro 1,203
       HDR Efex Pro Metadata 1,203
       Merge to HDR Efex Pro 1,203
       Nik Selective Tool 2.1.3.17710
    Plug-ins that failed to load: NONE
    Flash:
       Mini Bridge
       Kuler
    Installed TWAIN devices: NONE
    Jul 24, 2012 9:24 AM   in reply to Noel Carboni
    This is the only feature that is sluggish on my system - and I am sure GPU is working so maybe a bug in the GPU acceleration with this filter
    Mike
    Nov 20, 2012 6:01 AM   in reply to Noel Carboni
    I have Windows 7, 16 gigs ram, and updated drivers, CS6, and when I use the lighting effects it crashes Photoshop.   Same problem as everyone else here.   what can I do?   It seems that no one has a solution!
    Nov 20, 2012 7:00 AM   in reply to Noel Carboni
    While I am not experiencing a crash when using the filter it is woefully slow to initialize (see my post above). But crashes reliably toggling the preview on and off.
    Faulting module is msvcr100.dll
    Here is the capture from the Win7 (x64) Action Center
    Would be good to get an update on where this issue is as it's been out there a while
    Mike
    Apr 1, 2013 10:49 PM   in reply to Noel Carboni
    Was this ever resolved?  I'm having the same issue with CS6 crashing after toggling Preview on/off several times while working with Filter > Render > Lighting Effects and I can reliably cause the failure.  I'm on Windows 7 64-bit, PS CS6 realease 13.0.1 x64, using Gigabyte HD7970 with Intel i7-3770 with 32GB RAM (Vingeance).  Performance is excellent on almost all advanced functions in CS6, and this is the only hard failure issue I've experienced.  If I avoid the Preview button at top of screen, I am able to create the effect & save results, and I have found that I can toggle the eyeball on/off on a Smart Object Layer containing the Lighting Effects and that does NOT cause a failure so far...
