When I launch the Installer for Adobe Air Version 3.3 I get the End user license agreement. I can either click "I Agree" or "cancel". If I click "I Agree" I recieve another agreement in a new window as long as I click "I Agree" this is infinite or till all memory is consumed. If I click cancel then I get a permissions error and the install fails.
No MSI Install log is Generated. Here is the Air install Log.
[2012-07-24:09:06:40] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-07-24:09:06:40] Commandline is:
[2012-07-24:09:06:40] No installed runtime detected
[2012-07-24:09:06:42] Relaunching with elevation
[2012-07-24:09:06:42] Launching subprocess with commandline c:\users\wayne\appdata\local\temp\air1525.tmp\adobe air installer.exe -ei
[2012-07-24:09:06:42] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-07-24:09:06:42] Commandline is:
[2012-07-24:09:06:42] No installed runtime detected
[2012-07-24:09:06:45] Relaunching with elevation
[2012-07-24:09:06:45] Launching subprocess with commandline c:\users\wayne\appdata\local\temp\air1525.tmp\adobe air installer.exe -ei
[2012-07-24:09:06:45] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-07-24:09:06:45] Commandline is:
[2012-07-24:09:06:45] No installed runtime detected
[2012-07-24:09:06:47] Relaunching with elevation
[2012-07-24:09:06:47] Launching subprocess with commandline c:\users\wayne\appdata\local\temp\air1525.tmp\adobe air installer.exe -ei
[2012-07-24:09:06:47] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-07-24:09:06:47] Commandline is:
[2012-07-24:09:06:47] No installed runtime detected
[2012-07-24:09:06:49] Relaunching with elevation
[2012-07-24:09:06:49] Launching subprocess with commandline c:\users\wayne\appdata\local\temp\air1525.tmp\adobe air installer.exe -ei
[2012-07-24:09:06:49] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-07-24:09:06:49] Commandline is:
[2012-07-24:09:06:49] No installed runtime detected
[2012-07-24:09:06:51] Relaunching with elevation
[2012-07-24:09:06:51] Launching subprocess with commandline c:\users\wayne\appdata\local\temp\air1525.tmp\adobe air installer.exe -ei
[2012-07-24:09:06:51] Runtime Installer begin with version 3.3.0.3670 on Windows Vista x86
[2012-07-24:09:06:51] Commandline is:
[2012-07-24:09:06:51] No installed runtime detected
[2012-07-24:09:06:53] Runtime Installer end with exit code 6
[2012-07-24:09:06:53] Elevated install failed: returned error code -1
[2012-07-24:09:06:53] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Launching elevated sub-installer failed" errorID=5100]
[2012-07-24:09:06:54] Runtime Installer end with exit code 7
[2012-07-24:09:06:54] Elevated install failed: returned error code -1
[2012-07-24:09:06:54] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Launching elevated sub-installer failed" errorID=5100]
[2012-07-24:09:06:55] Runtime Installer end with exit code 7
[2012-07-24:09:06:56] Elevated install failed: returned error code -1
[2012-07-24:09:06:56] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Launching elevated sub-installer failed" errorID=5100]
[2012-07-24:09:06:57] Runtime Installer end with exit code 7
[2012-07-24:09:06:58] Elevated install failed: returned error code -1
[2012-07-24:09:06:58] Exiting due to error: [ErrorEvent type="error" bubbles=false cancelable=false eventPhase=2 text="Launching elevated sub-installer failed" errorID=5100]
[2012-07-24:09:06:58] Runtime Installer end with exit code 7
[2012-07-24:09:06:59] Runtime Installer end with exit code 7
I have removed ALL adobe products from my machine and I have run the following cleaners.
acrobat_ittools_cleaner_p1_040612
adobe_creative_suite_cleaner_tool
uninstall_flash_player
AIR Cleanup (log only).vbs (manualy deleted all directorys listed)
I have deleted all adobe and macromedia directorys and tried a CLEAN install and still I get this problem. I tried running the installer on command line with the -uninstall option to see if anything is still showing up and it errors saying not installed.
Windows 7 Pro 64bit SP 1
All Windows Updates are Installed
North America
Asia Pacific
