Acrobat FormsCentral Javascript
Jul 24, 2012 4:27 PM
Tags: #acrobat #javascript #formscentral
If I want to add Javascript to the components in a form, my workaround is to export the online form from FormsCentral and save as a PDF, open in Acrobat Pro then use the Tools/Form option to add Javascript to the Submit buttom and textboxes. Is this the right approach? I'm asking because I don't know if there is a straight-forward feature in Acrobat or FormsCentral to do this and if there is something implemented that is easier than this approach, thanks! When I try to create a form through Acrobat Pro it tells me to open FormsCentral to create the form but I want to have the ability to use Javascript in Acrobat to create the form.
  • Randy Swineford
    Mar 7, 2011
    Jul 24, 2012 4:32 PM   in reply to helennong
    Your workflow is fine. Just wondering what FormsCentral isn't doing for you - why do you need to add the JS?
    Apr 19, 2014 6:57 AM   in reply to Randy Swineford
    Hello same problem, I have to use the javascript code.
    The reason is that I have to create an order form where the customer enters the quantity of products and I would like the total field of compilassero automatically as in a spreadsheet.
    How can I do this? Since FORMCENTRAL not allow inseirmento of Javascipt.
    I use Adobe Acrobat XI cc.
    I look forward to feedback.
  • George Johnson
    Aug 11, 2002
    Apr 19, 2014 11:34 AM   in reply to Digitalnat
    If you're working with a PDF exported from FormsCentral, you first have to open it in Acrobat and select: File > Save a Copy
    Then open this new file (it doesn't open automatically) and make your changes in Acrobat. Here's some more info: http://forums.adobe.com/docs/DOC-3661
