I am building a dreamweaver webpage though a template.
for some reason it will not change the spry menu bar to update the changes made to the links on it.
that and the links won't work on the website (i uploaded it to a test website).
I am not sure if it is the same problem.
I changed the links from site to document relative.
I also checked the codes in http://validator.w3.org/check and http://jigsaw.w3.org/css-validator/ .
I also read this link and it didn't help me http://helpx.adobe.com/dreamweaver/kb/paths-dreamweaver-templates.html .
Can someone help please!
Thank you
When I look at the markup for the menu
<ul id="MenuBar">
<li> <a href="#">Home</a></li>
<li> <a href="#">About Jan Kardys</a></li>
<li> <a href="#">Resources</a>
<ul>
<li> <a href="#">Education Connection</a></li>
<li> <a href="#">Submission Guidelines</a></li>
<li> <a href="#">Blogs</a>
<ul>
<li> <a href="#">Unicorn Writers Conference</a></li>
<li> <a href="http://advancenetworkingunicorn.blogspot.com/">Advanced Netwroking Blog</a></li>
</ul>
</li>
<li> <a href="#">First Steps to Publishing</a></li>
<li> <a href="#">Library & Publishing Events</a></li>
<li> <a href="#">Art Gallery</a></li>
</ul>
</li>
<li> <a href="#">Clients</a></li>
<li> <a href="#">Contact Jan Kardys</a></li>
</ul>
I see just one link that being for Advanced Networking Blog.
There are several possible reasons
Gramps
When I made the update it asked me to update the pages and i said yes.
I assume that is what you are talking about. (I used the template because I have alot of pages that look similar with just different content on it).
When I finished the update I told it to upload everything to the website.
Here is the template code-maybe that will help.
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<!-- TemplateBeginEditable name="doctitle" -->
<title>Jan Kardys' Literary Agency</title>
<!-- TemplateEndEditable -->
<style type="text/css">
#header {
float: left;
width: 1000px;
#Menu_bar {
float: left;
width: 190px;
#Page_Content {
float: right;
width: 1000px;
font-family: "MS Serif", "New York", serif;
#footer {
float: left;
width: 1000px;
#Main_content {
float: left;
width: 395px;
padding-left: 100px;
#xtra_content {
float: right;
width: 395px;
padding-right: 100px;
#container {
width: 1000px;
margin: 0 auto;
background-image: url(/Images/Parchment.gif);
overflow: hidden;
#header_title {
font-family: "Trebuchet MS", Arial, Helvetica, sans-serif;
color: #0C3;
float: left;
#header_menubar {
float: right;
</style>
body {
</style>
<script src="/js/enhance.js" type="text/javascript"></script>
<script src="http://www.google.com/jsapi" type="text/javascript"></script>
<script src="http://labs.adobe.com/technologies/spry/ui/includes/SpryDOMUtils.js"" type="text/javascript"></script>
<script src="/Spry-UI-1.7/includes/SpryDOMUtils.js" type="text/javascript"></script>
<script src="/Spry-UI-1.7/includes/SpryDOMEffects.js" type="text/javascript"></script>
<script src="http://labs.adobe.com/technologies/spry/ui/includes/SpryWidget.js" type="text/javascript"></script>
<script src="/Spry-UI-1.7/includes/SpryMenu.js" type="text/javascript"></script>
<script src="/Spry-UI-1.7/includes/plugins/MenuBar2/SpryMenuBarKeyNavigationP lugin.js" type="text/javascript"></script>
<script src="/Spry-UI-1.7/includes/plugins/MenuBar2/SpryMenuBarIEWorkaroundsP lugin.js" type="text/javascript"></script>
<script type="text/xml">
<oa:widgets>
<oa:widget wid="2466548" binding="#OAWidget" />
<oa:widget wid="2141544" binding="#MenuBar" />
</oa:widgets>
</script>
<link href="/css/basic.css" rel="stylesheet" type="text/css" />
<link href="/Spry-UI-1.7/css/Menu/basic/SpryMenuBasic.css" rel="stylesheet" type="text/css" />
/* BeginOAWidget_Instance_2141544: #MenuBar */
/* Settable values for skinning a Basic menu via presets. If presets are not sufficient, most skinning should be done in
these rules, with the exception of the images used for down or right pointing arrows, which are in the file SpryMenuBasic.css
These assume the following widget classes for menu layout (set in a preset)
.MenuBar - Applies to all menubars - default is horizontal bar, all submenus are vertical - 2nd level subs and beyond are pull-right.
.MenuBarVertical - vertical main bar; all submenus are pull-right.
You can also pass in extra classnames to set your desired top level menu bar layout. Normally, these are set by using a preset.
They only apply to horizontal menu bars:
MenuBarLeftShrink - The menu bar will be horizontally 'shrinkwrapped' to be just large enough to hold its items, and left aligned
MenuBarRightShrink - Just like MenuBarLeftShrink, but right aligned
MenuBarFixedLeft - Fixed at a specified width set in the rule '.MenuBarFixedLeft', and left aligned.
MenuBarFixedCentered - - Fixed at a specified width set in the rule '.MenuBarFixedCentered',
and centered in its parent container.
MenuBarFullwidth - Grows to fill its parent container width.
In general, all rules specified in this file are prefixed by #MenuBar so they only apply to instances of the widget inserted along
with the rules. This permits use of multiple MenuBarBasic widgets on the same page with different layouts. Because of IE6 limitations,
there are a few rules where this was not possible. Those rules are so noted in comments.
#MenuBar {
background-color:transparent;
font-family: "Trebuchet MS", Arial, Helvetica, sans-serif; /* Specify fonts on on MenuBar and subMenu MenuItemContainer, so MenuItemContainer,
MenuItem, and MenuItemLabel
at a given level all use same definition for ems.
Note that this means the size is also inherited to child submenus,
so use caution in using relative sizes other than
100% on submenu fonts. */
font-weight: normal;
font-size: 16px;
font-style: normal;
padding:0;
border-color: #ffffff #ffffff #ffffff #ffffff;
border-width:0px;
border-style: none none none none;
/* Caution: because ID+class selectors do not work properly in IE6, but we want to restrict these rules to just this
widget instance, we have used string-concatenated classnames for our selectors for the layout type of the menubar
in this section. These have very low specificity, so be careful not to accidentally override them. */
.MenuBar br { /* using just a class so it has same specificity as the ".MenuBarFixedCentered br" rule bleow */
display:none;
.MenuBarLeftShrink {
float: left; /* shrink to content, as well as float the MenuBar */
width: auto;
.MenuBarRightShrink {
float: right; /* shrink to content, as well as float the MenuBar */
width: auto;
.MenuBarFixedLeft {
float: left;
width: 80em;
.MenuBarFixedCentered {
float: none;
width: 80em;
margin-left:auto;
margin-right:auto;
.MenuBarFixedCentered br {
clear:both;
display:block;
.MenuBarFixedCentered .SubMenu br {
display:none;
.MenuBarFullwidth {
float: left;
width: 100%;
/* Top level menubar items - these actually apply to all items, and get overridden for 1st or successive level submenus */
#MenuBar .MenuItemContainer {
padding: 0px 0px 0px 0px;
margin: 0; /* Zero out margin on the item containers. The MenuItem is the active hover area.
For most items, we have to do top or bottom padding or borders only on the MenuItem
or a child so we keep the entire submenu tiled with items.
Setting this to 0 avoids "dead spots" for hovering. */
#MenuBar .MenuItem {
border-width:1px;
border-color: #cccccc #ffffff #cccccc #ffffff;
border-style: none solid none solid;
#MenuBar .MenuItemFirst {
#MenuBar .MenuItemLast {
border-style: none solid none none;
#MenuBar .MenuItem .MenuItemLabel{
text-align:center;
line-height:1.4em;
color:#33ff66;
padding: 6px 15px 6px 15px;
width: 10em;
width:auto;
.SpryIsIE6 #MenuBar .MenuItem .MenuItemLabel{
width:1em; /* Equivalent to min-width in modern browsers */
/* First level submenu items */
#MenuBar .SubMenu .MenuItem {
font-family: Arial, Helvetica, sans-serif;
font-size: 14px;
font-style: normal;
padding:0px 2px 0px 0px;
border-width:1px;
border-color: #cccccc #cccccc #cccccc #cccccc;
/* Border styles are overriden by first and last items */
border-style: solid solid none solid;
#MenuBar .SubMenu .MenuItemFirst {
#MenuBar .SubMenu .MenuItemFirst .MenuItemLabel{
padding-top: 6px;
#MenuBar .SubMenu .MenuItemLast {
border-style: solid solid solid solid;
#MenuBar .SubMenu .MenuItemLast .MenuItemLabel{
padding-bottom: 6px;
#MenuBar .SubMenu .MenuItem .MenuItemLabel{
text-align:left;
line-height:1em;
color:#00ff33;
padding: 6px 5px 6px 5px;
width: 7em;
width:auto;
/* Hover states for containers, items and labels */
#MenuBar .MenuItemHover {
background-color: transparent;
#MenuBar .MenuItemWithSubMenu.MenuItemHover .MenuItemLabel{
background-color: transparent; /* consider exposing this prop separately*/
color: #000000;
#MenuBar .MenuItemHover .MenuItemLabel{
color: #000000;
#MenuBar .SubMenu .MenuItemHover {
#MenuBar .SubMenu .MenuItemHover .MenuItemLabel{
color: #333333;
/* Submenu properties -- First level of submenus */
#MenuBar .SubMenuVisible {
min-width:0%; /* This keeps the menu from being skinnier than the parent MenuItemContainer - nice to have but not available on ie6 */
border-width:0px;
#MenuBar.MenuBar .SubMenuVisible {/* For Horizontal menubar only */
top: 100%; /* 100% is at the bottom of parent menuItemContainer */
left:0px; /* 'left' may need tuning depending upon borders or padding applied to menubar MenuItemContainer or MenuItem,
and your personal taste.
0px will left align the dropdown with the content area of the MenuItemContainer. Assuming you keep the margins 0
on MenuItemContainer and MenuItem on the parent
menubar, making this equal the sum of the MenuItemContainer & MenuItem padding-left will align
the dropdown with the left of the menu item label.*/
z-index:10;
#MenuBar.MenuBarVertical .SubMenuVisible {
top: 0px;
left:100%;
min-width:0px; /* Do not neeed to match width to parent MenuItemContainer - items will prevent total collapse */
/* Submenu properties -- Second level submenu and beyond - these are visible descendents of .MenuLevel1 */
#MenuBar .MenuLevel1 .SubMenuVisible {
min-width:0px; /* Do not neeed to match width to parent MenuItemContainer - items will prevent total collapse*/
top: 0px; /* If desired, you can move this down a smidge to separate top item''s submenu from menubar -
that is really only needed for submenu on first item of MenuLevel1, or you can make it negative to make submenu more
vertically 'centered' on its invoking item */
left:100%; /* If you want to shift the submenu left to partially cover its invoking item, you can add a margin-left with a
negative value to this rule. Alternatively, if you use fixed-width items, you can change this left value
to use px or ems to get the offset you want. */
/* IE6 rules - you can delete these if you do not want to support IE6 */
/* A note about multiple classes in IE6.
* Some of the rules above use multiple class names on an element for selection, such as "hover" (MenuItemHover) and "has a subMenu" (MenuItemWithSubMenu),
* giving the selector '.MenuItemWithSubMenu.MenuItemHover'.
* Unfortunately IE6 does not support using mutiple classnames in a selector for an element. For a selector such as '.foo.bar.baz', IE6 ignores
* all but the final classname (here, '.baz'), and sets the specificity accordingly, counting just one of those classs as significant. To get around this
* problem, we use the plugin in SpryMenuBarIEWorkaroundsPlugin.js to generate compound classnames for IE6, such as 'MenuItemWithSubMenuHover'.
* Since there are a lot of these needed, the plugin does not generate the extra classes for modern browsers, and we use the CSS2 style mutltiple class
* syntax for that. Since IE6 both applies rules where
* it should not, and gets the specificity wrong too, we have to order rules carefully, so the rule misapplied in IE6 can be overridden.
* So, we put the multiple class rule first. IE6 will mistakenly apply this rule. We follow this with the single-class rule that it would
* mistakenly override, making sure the misinterpreted IE6 specificity is the same as the single-class selector, so the latter wins.
* We then create a copy of the multiple class rule, adding a '.SpryIsIE6' class as context, and making sure the specificity for
* the selector is high enough to beat the single-class rule in the "both classes match" case. We place the IE6 rule at the end of the
* css style block to make it easy to delete if you want to drop IE6 support.
* If you decide you do not need IE6 support, you can get rid of these, as well as the inclusion of the SpryMenuBarIEWorkaroundsPlugin.js script.
* The 'SpryIsIE6' class is placed on the HTML element by the script in SpryMenuBarIEWorkaroundsPlugin.js if the browser is Internet Explorer 6. This avoids the necessity of IE conditional comments for these rules.
.SpryIsIE6 #MenuBar .MenuBarView .MenuItemWithSubMenuHover .MenuItemLabel /* IE6 selector */{
color: #000000;
.SpryIsIE6 #MenuBar .MenuBarView .SubMenu .MenuItemWithSubMenuHover .MenuItemLabel/* IE6 selector */{
color: #333333;
.SpryIsIE6 #MenuBar .SubMenu .SubMenu /* IE6 selector */{
margin-left: -0px; /* Compensates for at least part of an IE6 "double padding" version of the "double margin" bug */
/* EndOAWidget_Instance_2141544 */
</style>
<!-- TemplateBeginEditable name="head" -->
</head>
<body>
<div id= "container">
<div id="header">
<div id="header_title"><h1>Jan kardy's Literary Agency</h1></div>
<div id="header_menubar">
</li>
</ul>
<!-- TemplateBeginEditable name="menubar_region" -->
<ul id="MenuBar">
<li> <a href="../index.html">Home</a></li>
<li> <a href="../about_jankardys.html">About Jan Kardys</a></li>
<ul>
<li> <a href="/Education_connection.html">Education Connection</a></li>
<li> <a href="/submission_guidelines.html">Submission Guidelines</a> </li>
<ul>
<li> <a href="Unicorn" _mce_href="http://unicornwritersconferencect.blogspot.com/">Unicorn"> http://unicornwritersconferencect.blogspot.com/">Unicorn Writers Conference</a></li>
<li> <a href="Advanced" _mce_href="http://advancenetworkingunicorn.blogspot.com/">Advanced">h ttp://advancenetworkingunicorn.blogspot.com/">Advanced Netwroking Blog</a></li>
</ul>
</li>
<li> <a href="#">Art Gallery</a> </li>
</ul>
</li>
<li> <a href="#">Contact Jan Kardys</a> </li>
</ul>
<!-- TemplateEndEditable --><script type="text/javascript">
// BeginOAWidget_Instance_2141544: #MenuBar
var MenuBar = new Spry.Widget.MenuBar2("#MenuBar", {
widgetID: "MenuBar",
widgetClass: "MenuBar MenuBarLeftShrink",
insertMenuBarBreak: true,
mainMenuShowDelay: 200,
mainMenuHideDelay: 200,
subMenuShowDelay: 200,
subMenuHideDelay: 200
// EndOAWidget_Instance_2141544
</script>
</li>
</ul>
</div>
</div>
<div id="Page_Content"><!-- TemplateBeginEditable name="Content_main_editable" -->
<div id="Main_content">hi</div>
<!-- TemplateEndEditable --><!-- TemplateBeginEditable name="Xtra_content_editable" -->
<div id="xtra_content">
<h3>News & Events </h3>
<p> </p>
</div>
<!-- TemplateEndEditable --></div>
<div id="footer"> <h6>Webpage designed by James S. Molina</h6></div>
</div>
</body>
</html>
I am not sure why that will not upload to the site correctly.
I am uploading to a godaddy server. Is there a way I should be saving things (links and such) that I might be doing wrong? am I naming my links incorrectly? how do I make them so they will work once uploaded.
I followed the suggestions that you made and it looks like it is there but for somereason when i preview the page in a browser or live view the background image (parchment) doesn't show up on the screen.and the spry menu bar only comes up as an unordered list. I am not sure what would be causing this.
I have attached the code for 2 pages the first is the code of the template test file you suggested I make and the second is the code for the education connection page (this is a page that was made from the template and the background image is not working-i had this problem before but i thought it was fixed as the website has it fixed when i published it)
TEST SITE:
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="file:///C|/Users/james/Documents/DREAMWEAVER SITES/JanKardys.com/Templates/Main_sitepage_template.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
<!-- InstanceBeginEditable name="doctitle" -->
<!-- InstanceEndEditable -->
#header {
float: left;
width: 1000px;
#Menu_bar {
float: left;
width: 190px;
#Page_Content {
float: right;
width: 1000px;
#footer {
float: left;
width: 1000px;
#Main_content {
float: left;
width: 395px;
#xtra_content {
float: right;
width: 395px;
#container {
width: 1000px;
margin: 0 auto;
background-image: url(file:///C|/Users/james/Documents/DREAMWEAVER SITES/JanKardys.com/Images/Parchment.gif);
overflow: hidden;
#header_title {
color: #0C3;
float: left;
#header_menubar {
float: right;
</style>
body {
</style>
<oa:widgets>
</oa:widgets>
</script>
#MenuBar {
font-size: 16px;
font-style: normal;
padding:0;
border-width:0px;
display:none;
width: auto;
width: auto;
.MenuBarFixedLeft {
float: left;
width: 80em;
float: none;
width: 80em;
margin-left:auto;
margin-right:auto;
clear:both;
display:block;
display:none;
.MenuBarFullwidth {
float: left;
width: 100%;
border-width:1px;
text-align:center;
line-height:1.4em;
color:#33ff66;
width: 10em;
width:auto;
font-size: 14px;
font-style: normal;
border-width:1px;
padding-top: 6px;
text-align:left;
line-height:1em;
color:#00ff33;
width: 7em;
width:auto;
color: #000000;
color: #000000;
color: #333333;
border-width:0px;
z-index:10;
top: 0px;
left:100%;
color: #000000;
color: #333333;
</style>
<!-- InstanceBeginEditable name="head" -->
</head>
<body>
<div id="header">
</li>
</ul>
<!-- InstanceBeginEditable name="menubar_region" -->
<ul id="MenuBar">
<li> <a href="file:///C|/Users/james/Documents/DREAMWEAVER SITES/JanKardys.com/index.html">Home</a></li>
<li> <a href="file:///C|/Users/james/Documents/DREAMWEAVER SITES/JanKardys.com/about_jankardys.html">About Jan Kardys</a></li>
<ul>
<ul>
<li> <a href="http://unicornwritersconferencect.blogspot.com/">Unicorn Writers Conference</a></li>
</ul>
</li>
</ul>
</li>
</ul>
<!-- InstanceEndEditable --><script type="text/javascript">
</script>
</li>
</ul>
</div>
</div>
<div id="Page_Content"><!-- InstanceBeginEditable name="Content_main_editable" -->
<!-- InstanceEndEditable --><!-- InstanceBeginEditable name="Xtra_content_editable" -->
<p> </p>
</div>
<!-- InstanceEndEditable --></div>
</div>
</body>
<!-- InstanceEnd --></html>
EDUCATION CONNECTION CODE:
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/Main_sitepage_template.dwt" codeOutsideHTMLIsLocked="false" -->
<head>
#header {
float: left;
width: 1000px;
#Menu_bar {
float: left;
width: 190px;
#Page_Content {
float: right;
width: 1000px;
#footer {
float: left;
width: 1000px;
#Main_content {
float: left;
width: 395px;
#xtra_content {
float: right;
width: 395px;
#container {
width: 1000px;
margin: 0 auto;
overflow: hidden;
#header_title {
color: #0C3;
float: left;
#header_menubar {
float: right;
</style>
body {
</style>
<oa:widgets>
</oa:widgets>
</script>
#MenuBar {
font-size: 16px;
font-style: normal;
padding:0;
border-width:0px;
display:none;
width: auto;
width: auto;
.MenuBarFixedLeft {
float: left;
width: 80em;
float: none;
width: 80em;
margin-left:auto;
margin-right:auto;
clear:both;
display:block;
display:none;
.MenuBarFullwidth {
float: left;
width: 100%;
border-width:1px;
text-align:center;
line-height:1.4em;
color:#33ff66;
width: 10em;
width:auto;
font-size: 14px;
font-style: normal;
border-width:1px;
padding-top: 6px;
text-align:left;
line-height:1em;
color:#00ff33;
width: 7em;
width:auto;
color: #000000;
color: #000000;
color: #333333;
border-width:0px;
z-index:10;
top: 0px;
left:100%;
color: #000000;
color: #333333;
</style>
</head>
<body>
<div id="header">
</li>
</ul>
<ul id="MenuBar">
<li> <a href="/index.html">Home</a></li>
<li> <a href="/about_jankardys.html">About Jan Kardys</a></li>
<ul>
<ul>
</ul>
</li>
</ul>
</li>
</ul>
</script>
</li>
</ul>
</div>
</div>
<div id="Main_content"><img src="/Images/jankardys.jpg" width="171" height="234" alt="Jan_kardys_pictuer" /></div>
<center><h3>Signed Book Deal</h3>
<p><a href="http://jankardys.com/Advance_Royalties.html" title="Advance_Royalties.html">Advance/Royalties</a></p>
<p><a href="http://jankardys.com/Author_Quotes.html" title="Author_Quotes.html">Author Quotes</a></p>
<p><a href="http://jankardys.com/Book_Deal.html" title="Book_Deal.html">Book Deal</a></p>
<p><a href="http://jankardys.com/Copyright_Information.html" title="Copyright_Information.html">Copyright Information</a></p>
<p><a href="http://jankardys.com/Editorial_Assistance.html" title="Editorial_Assistance.html">Freelance Editorial Assistance</a></p>
<p><a href="http://jankardys.com/Electronic_Rights.html" title="Electronic_Rights.html">Electronic Rights Guidelines</a></p>
<p><a href="http://jankardys.com/Google_Products.html" title="Google_Products.html">Google Products</a></p>
<p><a href="http://jankardys.com/Out_of_Print_Reversions.html" title="Out_of_Print_Reversions.html">Out of Print Reversions</a></p>
<p><a href="http://jankardys.com/Permissions.html" title="Permissions.html">Permissions</a></p>
<p><a href="http://jankardys.com/Photo_release.html" title="Photo_release.html">Photo Release</a></p>
<p><a href="http://jankardys.com/Return_of_Advance.html" title="Return_of_Advance.html">Return of Advance</a></p>
<p><a href="http://jankardys.com/Subrights_Checklist.html" title="Subrights_Checklist.html">Subrights Checklist</a></p></center>
<p> </p>
<p> </p>
</div>
</div>
</body>
There are several problems that I see immediately in this TEST file:
1. First, there is clearly a problem with your site definition since a number of your links are poorly formed -
(That 'file:///' link should never happen - see the corresponding link in your second file)
also -
<ul>
Note that the first link is broken suggesting that DW thinks that file is OUTSIDE the root folder of the site, while the second link is a normal root relative link.
2. Your links in both pages are all either ABSOLUTE links, or ROOT RELATIVE links. Why are you not using simple document relative links? The link styles you are using will both cause you problems in maintaining or building your pages.
3. Your menu is within an editable region of the template. As such, changes made to the template in that region will never propagate to the child pages. It's only changes made to the non-editable regions of the template file that will propagate to child pages.
Ok so I redid the template it seemed eaiser than dealing with the mess that I had.
It looks like it will update now correctly (the spry bar).
I also went in and chose document relative links, so that should make it much eaiser.
I believe this will fix all of the issues that we are having with the links.
I have 2 questions.
1) the other pages that I made before off of the other template-would it be better to just remake them with this new template or should I just remove the old template and add this one?
2) I uploaded the website (it asked me to specifiy a test server so I chose the firsthelpamerica.us site server as the test server.) it won't open the file it says it is not found. is there a reason for that?
I want to be able to preview the site in dreamweaver (live view-which it seems to let me do) and also in a browser like ie or mozilla.
I am not sure why it won't let me? the big problem comes that I want to make sure the background image comes out correctly.
the only other thing that concerns me is 5 lines down it gives me this: codeOutsideHTMLIsLocked="false" -->
I thought it wasn't supposed to give me this. is there a reason why? or is it ok?
if not am i setting the file path incorrectly? I went into the manage sites and selected document relative paths under the advanced menu. (if that is not how you do it can you please direct me to the correct place)
Thank you again for all of your help.
I am going to post the code for the new template file just to make sure that it is ok.
Thank you
<%@LANGUAGE="JAVASCRIPT" CODEPAGE="65001"%>
<html xmlns="http://www.w3.org/1999/xhtml"><!-- InstanceBegin template="/Templates/test_template.dwt.asp" codeOutsideHTMLIsLocked="false" -->
<head>
<title>Test_template</title>
#container {
background-image: url(Images/DSC_0013.jpg);
width: 1000px;
overflow: hidden;
#header {
width: 1000px;
float: right;
#header_title {
color: #0F3;
float: left;
width: 500px;
#header_menubar {
float: right;
width: 500px;
</style>
<link href="Spry-UI-1.7/css/Menu/basic/SpryMenuBasic.css" rel="stylesheet" type="text/css" />
<script src="Spry-UI-1.7/includes/SpryDOMUtils.js" type="text/javascript"></script>
<script src="Spry-UI-1.7/includes/SpryDOMEffects.js" type="text/javascript"></script>
<script src="Spry-UI-1.7/includes/SpryWidget.js" type="text/javascript"></script>
<script src="Spry-UI-1.7/includes/SpryMenu.js" type="text/javascript"></script>
<script src="Spry-UI-1.7/includes/plugins/MenuBar2/SpryMenuBarKeyNavigationPl ugin.js" type="text/javascript"></script>
<script src="Spry-UI-1.7/includes/plugins/MenuBar2/SpryMenuBarIEWorkaroundsPl ugin.js" type="text/javascript"></script>
#MenuBar {
font-size: 16px;
font-style: normal;
padding:0;
border-width:0px;
display:none;
width: auto;
width: auto;
.MenuBarFixedLeft {
float: left;
width: 80em;
float: none;
width: 80em;
margin-left:auto;
margin-right:auto;
clear:both;
display:block;
display:none;
.MenuBarFullwidth {
float: left;
width: 100%;
border-width:1px;
text-align:center;
line-height:1.4em;
color:#33ff66;
width: 10em;
width:auto;
font-size: 14px;
font-style: normal;
border-width:1px;
padding-top: 6px;
text-align:left;
line-height:1em;
color:#00ff33;
width: 7em;
width:auto;
color: #000000;
color: #000000;
color: #333333;
border-width:0px;
z-index:10;
top: 0px;
left:100%;
color: #000000;
color: #333333;
#content_main {
float: left;
width: 495px;
#content_xtra {
float: right;
width: 495px;
#footer {
font-family: "Courier New", Courier, monospace;
color: #03C;
clear: both;
</style>
<oa:widgets>
</oa:widgets>
</script>
</head>
<body>
<div id="container">
<div id="header">
<div id="header_title"><h1>Jan Kardys Literary Agent</h1></div>
<ul id="MenuBar">
<li> <a href="index.html">Home</a></li>
<li> <a href="about_jankardys.html">About Jan Kardys</a></li>
<ul>
<ul>
</ul>
</li>
<li> <a href="http://google.com">First Steps to Publishing</a></li>
</ul>
</li>
</ul>
</script></div>
</div>
<!-- InstanceBeginEditable name="content_main_editable" -->
<div id="content_main">Content for id "content_main" Goes Here</div>
<!-- InstanceEndEditable --><!-- InstanceBeginEditable name="xtra_content_editable" -->
<div id="content_xtra">Content for id "content_xtra" Goes Here</div>
<div id="footer">Webmaster=LOKI</div>
</div>
</body>
I also realized that most of what I wanna do can be done with the css and not in the template so that was a derr moment on my part.
I still do have those questions above though.
I just have since removed the container image and placed it in a seperate style sheet that will apply to all new pages eaisly.
North America
Asia Pacific
