venkatl
PS CS6 action save for web error
Jul 25, 2012 1:59 AM
Tags: #photoshop #actions #cs6 #save_for_web
In Photoshop CS6 actions when we save the image as JPEG through save for web it doesn't work when we run it, instead it runs and saves the image as HTML, i guess some error in it. I tried it again and again but it doesn't remember my save for web settings and saves the images as HTML.
    Jul 25, 2012 2:46 AM   in reply to venkatl
    And if you rename the files afterwards?
  • JJMack
    Jan 9, 2006
    Jul 25, 2012 6:13 AM   in reply to venkatl
    Can you save the Action set and upload it to someplace we can download it and look at the actions something may be recorded badly.
  • JJMack
    Jan 9, 2006
    Jul 26, 2012 2:26 AM   in reply to venkatl
    It a new bug in CS6 though when you recorded the action you saved jpeg images to you desktop and you only entered file names onto the save for web action steps the action recorder recorded name.html.  I replaced you save for web steps on my machine for my desktop and CS6 recorded  name.html.  I then did the same with CS5 though I only entered names CS5 recorded name.jpg.
    If you expand the export steps tou will see the hard coded file names and extention
    An action like this will always save the same files it can not be batch because you recorded Path and Names in the save for web steps.  The .html files saved on with CS6 are actually jpeg files and if you rename them hrom name.html to name.jpg you can use them,
    Set: cropping
              Action: story sizes
                        Levels
                                  Preset Kind: Custom
                                  Adjustment: levels adjustment list
                                  levels adjustment
                                  Channel: composite channel
                                  Input: 0, 245
                                  Gamma: 1.14
                        Image Size
                                  Width: 660 pixels
                                  With Scale Styles
                                  With Constrain Proportions
                                  Interpolation: bicubic automatic
                        Export
                                  Using: Save for Web
                                  Operation: Save
                                  true
                                  In: C:\Users\venkatr\Desktop\
                                  Custom File Name:  “_660.html”   <----CS6 problem  recording - CS5 records "_660.jpg on my machine
                                  Format: JPEG
                                  Without Interlaced
                                  Quality: 55
                                  0
                                  Quality Modification Channel Strength: 0
                                  Without Quality Channel Text Layers
                                  Without Quality Channel Vector Layers
                                  With Optimized
                                  Number Of Passes: 3
                                  Blur: 0
                                  Without Embed ICC Profile
                                  With Matte
                                  Matte Color Red: 255
                                  Matte Color Green: 255
                                  Matte Color Blue: 255
                                  Without Save HTML File
                                  With Save Image Files
                                  Slices: All Slices
                                  Color Handling: Convert to sRGB
                                  Metadata: None
                                  Without Output XHTML
                                  With Include Comments
                                  With Always Add Alt Attribute
                                  With Always Quote Attributes
                                  Without Close All Tags
                                  With Include Zero Margins on Body Tag
                                  HTML Tags Case: Lowercase
                                  HTML Attribute Case: Lowercase
                                  HTML Indent: -1
                                  HTML Line Endings: Automatic
                                  <unknown>
                                  Without Generate CSS
                                  Empty Cells: GIF, IMG WH
                                  TD WH: Auto
                                  Vertical Spacer Cells: Auto (Bottom/Right)
                                  Horizontal Spacer Cells: Auto (Bottom/Right)
                                  Slice Name Components: Filename Component list
                                  Filename Component
                                  Filename Component Type: doc. name
                                  Filename Component
                                  Filename Component Type: underscore
                                  Filename Component
                                  Filename Component Type: layer name or slice no.
                                  Filename Component
                                  Filename Component Type: none
                                  Filename Component
                                  Filename Component
                                  Without View As Background
                                  Background Image Path:  “”
                                  Background Color Type: Matte
                                  File Name Components: Filename Component list
                                  Filename Component
                                  Filename Component Type: slice name
                                  Filename Component
                                  Filename Component Type: hyphen
                                  Filename Component
                                  Filename Component Type: trigger name
                                  Filename Component
                                  Filename Component
                                  Filename Component Type: rollover state
                                  Filename Component
                                  ...3 More
                                  Without Mac OS 9 Filename Compatibility
                                  With Windows Filename Compatibility
                                  With Unix Filename Compatibility
                                  With Use Images Subfolder
                                  With Copy Background Image when Saving
                                  Images Subfolder Path:  “images”
                        Select previous history state
                        Crop
                                  To: rectangle
                                  Top: 111.4 pixels
                                  Left: 142.2 pixels
                                  Bottom: 2342.6 pixels
                                  Right: 3613.1 pixels
                                  Angle: 0°
                                  Without Delete Cropped Pixels
                                  <unknown>
                                  Target Width: 350 pixels
                                  Target Height: 225 pixels
                                  Target Resolution: 0 per inch
                        Export
                                  Using: Save for Web
                                  Operation: Save
                                  true
                                  Custom File Name:  “_350.html”
                                  Format: JPEG
                                  Without Interlaced
                                  Quality: 55
                                  0
                                  With Optimized
                                  Number Of Passes: 3
                                  Blur: 0
                                  With Matte
                                  Slices: All Slices
                                  Metadata: None
                                  HTML Indent: -1
                                  <unknown>
                                  TD WH: Auto
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  ...3 More
                        Crop
                                  To: rectangle
                                  Top: 0 pixels
                                  Left: 529.1 pixels
                                  Bottom: 2730 pixels
                                  Right: 2869.1 pixels
                                  Angle: 0°
                                  <unknown>
                                  Target Width: 300 pixels
                                  Target Height: 350 pixels
                        Export
                                  Using: Save for Web
                                  Operation: Save
                                  true
                                  Custom File Name:  “_300.html”
                                  Format: JPEG
                                  Without Interlaced
                                  Quality: 55
                                  0
                                  With Optimized
                                  Number Of Passes: 3
                                  Blur: 0
                                  With Matte
                                  Slices: All Slices
                                  Metadata: None
                                  HTML Indent: -1
                                  <unknown>
                                  TD WH: Auto
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  ...3 More
                        Crop
                                  To: rectangle
                                  Top: 136.5 pixels
                                  Left: 325.7 pixels
                                  Bottom: 2359.2 pixels
                                  Right: 3295.2 pixels
                                  Angle: 0°
                                  <unknown>
                                  Target Width: 167 pixels
                                  Target Height: 125 pixels
                        Export
                                  Using: Save for Web
                                  Operation: Save
                                  true
                                  Custom File Name:  “_167.html”
                                  Format: JPEG
                                  Without Interlaced
                                  Quality: 55
                                  0
                                  With Optimized
                                  Number Of Passes: 3
                                  Blur: 0
                                  With Matte
                                  Slices: All Slices
                                  Metadata: None
                                  HTML Indent: -1
                                  <unknown>
                                  TD WH: Auto
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  ...3 More
                        Crop
                                  To: rectangle
                                  Top: 225.1 pixels
                                  Left: 1318.4 pixels
                                  Bottom: 1858.5 pixels
                                  Right: 3496.2 pixels
                                  Angle: 0°
                                  <unknown>
                                  Target Width: 88 pixels
                                  Target Height: 66 pixels
                        Export
                                  Using: Save for Web
                                  Operation: Save
                                  true
                                  Custom File Name:  “_88.html”
                                  Format: JPEG
                                  Without Interlaced
                                  Quality: 55
                                  0
                                  With Optimized
                                  Number Of Passes: 3
                                  Blur: 0
                                  With Matte
                                  Slices: All Slices
                                  Metadata: None
                                  HTML Indent: -1
                                  <unknown>
                                  TD WH: Auto
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  Filename Component
                                  ...3 More
                        Close
                                  Saving: no
    Jul 31, 2012 11:35 AM   in reply to venkatl
    This was reported more than 2 months ago and a Photoshop (Adobe) employee confirmed it as such.
    http://feedback.photoshop.com/photoshop_family/topics/ps_cs6_actions_r ecorded_action_exports_html_instead_of_jpg
    This is a HUGE inconvenience and surely needs to be addressed sooner than later.  I have found that importing actions from older versions will work...the only problem is if the machine name/user name/folder path changes it is worthless.
    Luckily I have PS5.5 installed on my other computers and I use that...however, I just got my new MBP with Retina and won't be able to install 5.5, only the CC6 version.
    Feb 25, 2013 2:47 PM   in reply to venkatl
    I'm having this same issue and falling back on CS5 to batch the actions.
