I store my photographs (around 6000 at moment) on an external frive (1TB). Should I still have to back up organiser? My problem is that if I open organiser in "Folder Location" mode then it is very slow to open. I use Photoshop Elements 9.
Jim
Yes I would recommend backing up particularly as external hdd’s are prone to failure. You can start from Organizer (press Ctrl+B) and on the first occasion make a full back-up. Periodically you can then make incremental backups which will be much quicker. You can use disks or a second external drive.
Folder Location view will be slow to open because the Organizer is going through your system to enumerate all the drives, folders, etc. Any work you do to the actual image files will also be slow because reading and writing to external drives is slower than accessing your internal drive.
PSE is a 32-bit application and the Organizer will only use at most about 3.2Gb of memory (on a 64-bit Windows system). With 4Gb of memory on your machine, you'll simply need to avoid running other applications in the background when using PSE.
Ken
Hi
Thank you for all the help received from this site. I wish I had discovered it a while ago when I first started using Organiser. The mistake I think I made then was to store my motor racing photographs on an external drive. I realise now that I should have stored it on my internal drive. I see now that backing up to the original destination seems self defeating. I have now copied all the files to a partition of the internal drive. The trouble is that Organiser is still using the files from the external drive. How can I make Organiser use the files from the PCs hard drive and just use the external drive for back up?
Jim
I assume you used Windows Explorer to copy the files to the new location and that the original files are still on your external drive. The simplest (and safest) thing to do is:
It'll take a while.
Ken
Hi
Thanks very much for your help. I have moved the files to another directory/folder on my external drive. I open Organiser and it seems to do nothing. I go File>"Reconnect all missing files" and it starts reconnecting immediately.Do you think it may be taking the files from my new folder in the external drive? How can I pause that process in order to open my internal drive directory/folder? Im sorry to be a pain
North America
Asia Pacific
