I want to have a help here to do this:
When I activate my saveCorrection script, I use it to modify/correct a single image tha it is present on a folder of 5, 6 or 7 images).
This means that I will have inside that folder 1 corrected images and also the other images I will need.
To simplfy my daily upload work, I decided to avoid uploading each individual folder each time I make a correction. So I start saving each corrected image to a daily global folder on my desktop.
At the ende of the day, I upload all my daily images I have corrected from that folder.
This is done and works great but I need also to upload the other not corrected images from that global folder.
For example:
Folder1 has 6 images
Folder2 has 5 images
Folder3 has 6 images
Folder4 has 4 images
I correct image1 from Folder2
and image4 of Folder4
The global folder needs to have not only this 2 images but also needs to read all the present images from a folder that had a correction and pasting them to the global daily folder.
At the end of the day I must have
GlobalFolder with 9 images from Folders 2 and 4
So I can I detect present files on a folder and passing them to another?
I only need to put all images together in a folder (anywhere).
After that, the uploading process is a batch done automatically from another app outside photoshop.
In less words, my question is:
How can I detect how many images there are in a folder each time I save only one image there and then get all the files there and transfer (copy/paste) all images to another folder anywhere (that global folder).
I assume you are on Windows, so something like this
// 2012, use it at your own risk;
#target photoshop
if (app.documents.length > 0) {
var myDocument = app.activeDocument;
var thePath = myDocument.path;
var theFiles = Folder(thePath).getFiles(/\.(jpg|tif|eps|psd)$/i);
alert (theFiles.join("\n"))
should get you the neighboring jps, tiffs, eps’, psds … amend the filter as needed.
Then you can iterate through the array (Edit: with a for-function) and use the method
File.copy (target: string)
to copy them somewhere else.
Thanks !
It helped me a lot simplifiing and finishing what I needed.
I also manage to automatically create the date to name the daily folder.
#target photoshop
var theDate = new Date();
var theYear = (theDate.getYear() + 1900).toString();
var mes = theDate.getMonth() + 1 ;
var theMonth = mes.toString();
if (theDate.getMonth() < 10) {
theMonth = "0" + theMonth;
var theDay = theDate.getDate().toString()
if (theDate.getDate() < 10) {
theDay = "0" + theDay;
theDate = theYear + "_" + theMonth + "_" + theDay;
var theFilesLength = Folder(thePath).getFiles(/\.(jpg)$/i).length;
var correctionsDayFolder = Folder("~/Desktop/upload/" + theDate + "_Corrections");
if (!correctionsDayFolder.exists) correctionsDayFolder.create();
for (var u=0 ; u< theFilesLength ; u++) {
fileCorr = Folder(thePath).getFiles(/\.(jpg)$/i)[u]
var nameCorr = Folder(thePath).getFiles(/\.(jpg)$/i)[u].name
fileCorr.copy(correctionsDayFolder + "/" + nameCorr)
North America
Asia Pacific
