drimnafinagle
Converting Abortext files into Framemaker
Jul 25, 2012 10:05 AM
Tags: #abortext
Hi Folks,
Currently we convert documentation from another company into our template. Previously they have provided us with Framemaker files that were obviously easy to convert across. In this instance they have provided Abortext and have discontinued providing Framemaker files.
What is the easiest ways to get these files into a format where they are editable using Framemaker? I do not have the abortext software so cannot open the files currently.
Regards,
Niall.
    Jul 25, 2012 10:08 AM   in reply to drimnafinagle
    What version of Framemaker you have?
    If its Framemaker 10,I think you can try and open that using S1000D template within Framemaker.
    Jul 25, 2012 10:27 AM   in reply to drimnafinagle
    Is it a boing documentations?
    if yes you can goto google and download S1000d for Frame 9 and try and open your file
    Jul 25, 2012 10:31 AM   in reply to drimnafinagle
    Whats the extension of your abortext file?
    Jul 25, 2012 10:33 AM   in reply to drimnafinagle
    > I'm afraid I don't know what a boing documentation is....
    I'd guess that Boeing is what was intended.
    Jul 25, 2012 10:38 AM   in reply to drimnafinagle
    You can open the XML files in Frame not 'met' files.
    try opening XML files and if they are valid ,frame will let you edit it as well.
    Jul 26, 2012 5:16 AM   in reply to drimnafinagle
    When you select File > Open in FrameMaker and select the xml file, FrameMaker should pop up with a dialog asking to select the structure application. Select No application. It should open the file and make an attempt to give it some formatting. Does all this happen? I doubt that it would display the XML code. I have never seen that.
