I have a purchase contract I need to have auto-fill in the date.
The line reads, "Made this ____ Day of ______, _______.
Filled-out it would read, ""Made this __3__Day of July__, 2012.
I currently have my form fill in other date fields formatted as mm/dd/yyyy using this script and wondered if someone might know how to modify the script to change the format?
function DateToday() {
this.getField("DateToday").value = util.printd("mm/dd/yyyy", new Date())
return true;
} // end of DateToday() function
Are they separate fields, or a single field?
Try this in the Calculation script for the field if you are using a single field (Otherwise, separate each value and use that for each individual field):
var d = new Date()
event.value = "Made this " + util.printd("d", d) + " Day of " + util.printd("mmmm", d) + ", " + util.printd("yyyy", d) + "."
Edit: If you need to use a separate function so the value doesn't change, you can alter your function
this.getField("DateToday").value = "Made this " + util.printd("d", d) + " Day of " + util.printd("mmmm", d) + ", " + util.printd("yyyy", d) + "."
return true;
North America
Asia Pacific
