pknight213
Printing from 3rd Party Software
Jul 25, 2012 12:30 PM
Tags: #printing #distiller_x
We create PDFs from programs we write in National Instruments LabWindows.  We use Adobe Distiller by creating a key in
Software\adobe\acrobat distiller\printerjobcontrol\.
This works well in Wndows XP, we create a pdf with a filename that the program created.  But when we  moved to Windows 7 it doesn't work.  When we execute the code, we get a window asking for a filename.
The WIndows XP computers are running Distiller 9, the Windows 7 computers are running Distiller X.
Is this feature still support in Distiller X?
    Jul 25, 2012 2:44 PM   in reply to pknight213
    The feature is still documented the same in the Acrobat X SDK. You might find this interesting if you are on 64 bit Windows (since the exe that prints is different from the one that is run): http://forums.adobe.com/thread/790897
    Jul 25, 2012 10:48 PM   in reply to Test Screen Name
    Don't know for sure, but I suspect you may have the preference in Distiller set to ask for a file name. That selection is under the File>Preferences menu in AA9 and I suspect a similar selection is in AAX.
    Aug 29, 2012 6:52 AM   in reply to pknight213
    So, did you change the key under PrinterJobControl, and if so, what to?
    Sep 4, 2012 10:23 AM   in reply to pknight213
    Ok, did you read the post I linked to in reply #1? Response #2 in that post suggests that in 64-bit Windows the name to use in your key is not c:\mfgtests\48-000055-001\48-000055-001.exe but the name of the 32-bit print spooler. You haven't said if you're using 64-bit Windows 7 so I don't know if that's relevant.
    Sep 15, 2012 3:24 AM   in reply to pknight213
    Well that's me out of ideas. Probably time to raise a developer support case.
