Prevent document close event/command
Jul 26, 2012 9:27 PM
Hi All,
I am trying to prevent document close event by using command interceptor mechanism but could not get succeed and document gets closed from layout window,
Is there exist a way so that document remains opened in layout window.?
I did followings
ICommandInterceptor::InterceptResult EDCmdInterceptor::InterceptProcessCommand(ICommand *cmd)
    InterceptResult result = kCmdNotHandled;
    do
        ClassID classID = GetClass(cmd);
        if(classID == kCloseDocCmdBoss)
            result = kCmdHandled;
    } while (false);
    return result;
ICommandInterceptor::InterceptResult EDCmdInterceptor::InterceptScheduleCommand(ICommand *cmd)
    do
        ICommand::CommandState state;
    } while (false);
    return result;
ICommandInterceptor::InterceptResult EDCmdInterceptor::InterceptExecuteImmediate(ICommand *cmd)
    do
    } while (false);
    return result;
ICommandInterceptor::InterceptResult EDCmdInterceptor::InterceptExecuteDynamic(ICommand *cmd)
    do
    } while (false);
    return result;
    Jul 31, 2012 2:04 AM   in reply to alam_84
    Instead of intercepting the kCloseDocCmdBoss, try to intercept the kClosePresentationCmdBoss.
    As when you close the layout window of the document the kClosePresentationCmdBoss is processed before scheduling of the kCloseDocCmdBoss.
    Jul 31, 2012 1:56 PM   in reply to alam_84
    Interfering with commands should be only used as last resort, there are many locations where the InDesign developers just assume commands always go through.
    Use forum search "IDocFileHandler" for an alternative.
    Dirk
