Problems with Adobe Flash Media Live Encoder 3.1
Jul 26, 2012 10:40 AM
Tags: none (add) #problem #adobe #flash #live #audio #media #encoder #stream #live_streaming #fms_3.5 #streaming_video #3.1Hello I use a version of Adobe Flash Media Encoder (3.1)
Recently doing a recording, we had the following problem.
After the recording lasted for 1 hour at 1:30 minutes, the generated video produced only 30 minutes!
Checking the video appears in the log as complete and the right length, but the final video has only 30 minutes.
Can someone help us?
Thank you
______________________________________________________________________ __________________________________________________
LOG - From the recording - the recording of which I speak is from 19:30
The first record of 17:30 was ok
File: C:\Program Files (x86)\Adobe\Flash Media Live Encoder 3.1\FlashMediaLiveEncoder.exe
Description: Adobe® Flash® Media Live Encoder
Copyright: © 2009 - 10 Adobe Systems Incorporated. All Rights Reserved. Adobe, the Adobe logo, and Flash are either registered trademarks or trademarks of Adobe Systems Incorporated in the United States and/or other countries. All other trademarks are the property of their respective owners. <AdobeIP#0000716>
Version: 3.1.0.8703
Mon Jul 23 2012 16:34:51 : Selected video input device: Osprey-230 Video Device 1
Mon Jul 23 2012 16:34:51 : Selected audio input device: Osprey-2X0 Audio 1 Unbalanced
Mon Jul 23 2012 16:37:37 : Selected video input device: Osprey-230 Video Device 1
<?xml version="1.0" encoding="UTF-16"?>
<flashmedialiveencoder_profile>
<preset>
<name>Custom</name>
<description></description>
</preset>
<capture>
<video>
<device>Osprey-230 Video Device 1</device>
<crossbar_input>0</crossbar_input>
<frame_rate>15.00</frame_rate>
<size>
<width>320</width>
<height>240</height>
</size>
</video>
<audio>
<device>Osprey-2X0 Audio 1 Unbalanced</device>
<sample_rate>22050</sample_rate>
<channels>2</channels>
<input_volume>75</input_volume>
</audio>
</capture>
<process>
<video>
<preserve_aspect></preserve_aspect>
</video>
</process>
<encode>
<video>
<format>VP6</format>
<datarate>200;</datarate>
<outputsize>320x240;</outputsize>
<advanced>
<keyframe_frequency>5 Seconds</keyframe_frequency>
<quality>Good Quality - Good Framerate</quality>
<noise_reduction>None</noise_reduction>
<datarate_window>Medium</datarate_window>
<cpu_usage>Dedicated</cpu_usage>
</advanced>
<autoadjust>
<enable>false</enable>
<maxbuffersize>1</maxbuffersize>
<dropframes>
</dropframes>
<degradequality>
<minvideobitrate></minvideobitrate>
<preservepfq>false</preservepfq>
</degradequality>
</autoadjust>
</video>
<audio>
<format>MP3</format>
<datarate>48</datarate>
</audio>
</encode>
<restartinterval>
<days></days>
<hours></hours>
<minutes></minutes>
</restartinterval>
<reconnectinterval>
<attempts></attempts>
<interval></interval>
</reconnectinterval>
<output>
<rtmp>
<url>rtmp://flash.asaweb.com.br/pesquisaincasa5</url>
<backup_url></backup_url>
<stream>pesquisaincasa5</stream>
</rtmp>
<file>
<limitbysize>
<size>10</size>
</limitbysize>
<limitbyduration>
<hours>1</hours>
<minutes>0</minutes>
</limitbyduration>
<path>C:\Clientes\Videos\GFK\GFK_Posicionamento_19_23_07_2012_17_30.f lv</path>
</file>
</output>
<metadata>
<entry>
<key>author</key>
<value></value>
</entry>
<entry>
<key>copyright</key>
<value></value>
</entry>
<entry>
<key>description</key>
<value></value>
</entry>
<entry>
<key>keywords</key>
<value></value>
</entry>
<entry>
<key>rating</key>
<value></value>
</entry>
<entry>
<key>title</key>
<value></value>
</entry>
</metadata>
<preview>
<video>
<input>
<zoom>100%</zoom>
</input>
<output>
<zoom>100%</zoom>
</output>
</video>
<audio></audio>
</preview>
<log>
<level>100</level>
<directory>C:\Users\incasa.INCASA2\Videos</directory>
</log>
</flashmedialiveencoder_profile>
DumpGraph [03D1DA28]
Filter [03D5B3A4] Output Video Renderer
Pin [03D5B77C] Input [Input] Connected to pin [02CE3698]
Filter [03D5A55C] Input Video Renderer
Pin [03D5A934] Input [Input] Connected to pin [02CC3008]
Filter [03D54B34] Meter Render Right
Pin [03D54F0C] Input [Input] Connected to pin [02CDDBE8]
Filter [03D56B34] Meter Render
Pin [03D56F0C] Input [Input] Connected to pin [02CD5240]
Filter [02CD1FA8] Mux
Pin [02CD2008] FLV4 [Input] Connected to pin [02CC4BE0]
Pin [02CD2828] MP3 [Input] Connected to pin [02CC69B8]
Pin [02CD2AA0] out [ Output] This pin is not Connected
Filter [02CE2F48] VP62_FL8 Compressor
Pin [02CE2F68] Input [Input] Connected to pin [02CE2DE8]
Pin [02CE3698] Preview [Output] Connected to pin [03D5B77C]
Pin [02CC4BE0] Output1 [Output] Connected to pin [02CD2008]
Pin [02CE5A08] Output2 [ Output] This pin is not Connected
Filter [02CC2F00] Input RGB
Pin [02CC2F18] Input [Input] Connected to pin [03D59F54]
Pin [02CC3008] Output [Output] Connected to pin [03D5A934]
Filter [02CC6850] Audio Encoder Tee
Pin [02CC6860] Input [Input] Connected to pin [02CDCA58]
Pin [02CC69B8] Output1 [Output] Connected to pin [02CD2828]
Pin [02CC4998] Output2 [ Output] This pin is not Connected
Filter [02CC8808] Audio Monitor
Pin [02CC8880] Input [Input] Connected to pin [03D92BF4]
Pin [02CD5240] Channel 0 [Output] Connected to pin [03D56F0C]
Pin [02CDDBE8] Channel 1 [Output] Connected to pin [03D54F0C]
Filter [02CE2668] FPS Controller Encoder
Pin [02CE2678] Input [Input] Connected to pin [02CE1EB0]
Pin [02CE2DE8] Output [Output] Connected to pin [02CE2F68]
Filter [02CDC550] Audio Encoder
Pin [02CDC558] PCM [Input] Connected to pin [03DA1B9C]
Pin [02CDCA58] MP3 [Output] Connected to pin [02CC6860]
Filter [02CE1DA8] Resize
Pin [02CE1DC0] Input [Input] Connected to pin [02CD9F30]
Pin [02CE1EB0] Output [Output] Connected to pin [02CE2678]
Filter [0036B82C] Audio Tee
Pin [0036B894] Input [Input] Connected to pin [02CD4660]
Pin [03DA1B9C] Output1 [Output] Connected to pin [02CDC558]
Pin [03D92BF4] Output2 [Output] Connected to pin [02CC8880]
Pin [03DA1E5C] Output3 [ Output] This pin is not Connected
Filter [02CD97B0] FPS Controller Resize
Pin [02CD97C0] Input [Input] Connected to pin [03D1E33C]
Pin [02CD9F30] Output [Output] Connected to pin [02CE1DC0]
Filter [02CD3F20] Audio Resampler
Pin [02CD3F28] In [Input] Connected to pin [02CD5000]
Pin [02CD4660] PCM [Output] Connected to pin [0036B894]
Filter [03D57974] Video Tee
Pin [03D579DC] Input [Input] Connected to pin [0036B564]
Pin [03D59F54] Output1 [Output] Connected to pin [02CC2F18]
Pin [03D1E33C] Output2 [Output] Connected to pin [02CD97C0]
Pin [03D1E3FC] Output3 [ Output] This pin is not Connected
Filter [02CD48D8] Audio Filler
Pin [02CD48E0] In [Input] Connected to pin [03D9AA7C]
Pin [02CD5000] Output [Output] Connected to pin [02CD3F28]
Filter [03D9A8D4] AUDIO SOURCE
Pin [03D9AA7C] Capture [Output] Connected to pin [02CD48E0]
Pin [03DA17E4] Volume principal [ Input] This pin is not Connected
Filter [00369BF4] SOURCE
Pin [0036B564] Capturar [Output] Connected to pin [03D579DC]
Pin [03D9EC7C] Visualizar [ Output] This pin is not Connected
Pin [03D9E9B4] CC [ Output] This pin is not Connected
Pin [03D9BCC4] VBI [ Output] This pin is not Connected
Pin [03D5CAA4] Entrada de vídeo analógica [Input] Connected to pin [00369E7C]
Filter [03D1DC24] Osprey-230 Crossbar 1
Pin [03D1DEFC] 0: Video Composite In [ Input] This pin is not Connected
Pin [03D1E05C] 1: Video SVideo In [ Input] This pin is not Connected
Pin [00369E7C] 0: Video Decoder Out [Output] Connected to pin [03D5CAA4]
Major type {73646976-0000-0010-8000-00AA00389B71} MEDIATYPE_Video
Sub type {E436EB7E-524F-11CE-9F53-0020AF0BA770} MEDIASUBTYPE_RGB32
Not temporally compressed
Sample size 307200
Source rectangle ( Left 0 Top 0 Right 0 Bottom 0)
Target rectangle ( Left 0 Top 0 Right 0 Bottom 0)
Size of BITMAPINFO structure 40
320 x 240, 32 bpp c:0
Image size 307200
Planes 1
Pels per metre (0, 0)
Colours used 0
AvgTimePerFrame 666666, 15 fps
Sub type {E436EB7D-524F-11CE-9F53-0020AF0BA770} MEDIASUBTYPE_RGB24
Sample size 230400
320 x 240, 24 bpp c:0
Image size 230400
Planes 1
Colours used 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
AvgTimePerFrame 0, 0 fps
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Sub type {34564C46-0000-0010-8000-00AA00389B71} Unknown GUID Name
Temporally compressed
Variable size samples
320 x 240, 12 bpp c:34564c46
Image size 115200
Planes 1
Colours used 0
Major type {73647561-0000-0010-8000-00AA00389B71} MEDIATYPE_Audio
Sub type {00000055-0000-0010-8000-00AA00389B71} Unknown GUID Name
Sample size 0
Format type FORMAT_WaveFormatEx
Subtype Unknown GUID Name
wFormatTag 85
nChannels 2
nSamplesPerSec 22050
nAvgBytesPerSec 6000
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sub type {30323449-0000-0010-8000-00AA00389B71} Unknown GUID Name
Sample size 115200
320 x 240, 12 bpp c:30323449
Image size 115200
Planes 1
Colours used 0
Sample size 307200
Image size 307200
Planes 1
Colours used 0
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 230400
Image size 230400
Planes 1
Colours used 0
Sample size 1
wFormatTag 85
nChannels 2
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 1
wFormatTag 85
nChannels 2
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sub type {00000001-0000-0010-8000-00AA00389B71} MEDIASUBTYPE_PCM
Sample size 4
Subtype MEDIASUBTYPE_PCM
wFormatTag 1
nChannels 2
nAvgBytesPerSec 88200
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 1
wFormatTag 85
nChannels 2
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Major type {0482DDE1-7817-11CF-8A03-00AA006ECB65} MEDIATYPE_AnalogVideo
Sub type {E436EB8E-524F-11CE-9F53-0020AF0BA770} MEDIASUBTYPE_None
Sample size 1
Format type FORMAT_AnalogVideo
Sample size 1
Mon Jul 23 2012 17:48:44 : Problem with Primary Server. Failure to connect to Primary server. Please verify that your Server URL and application name are valid and that your Internet connection is working and retry.
Mon Jul 23 2012 17:48:44 : Session Started
Mon Jul 23 2012 17:48:44 : Video Encoding Started
Mon Jul 23 2012 17:48:44 : Audio Encoding Started
Mon Jul 23 2012 19:37:52 : Audio Encoding Stopped
Mon Jul 23 2012 19:37:52 : Video Encoding Stopped
Mon Jul 23 2012 19:37:52 : Session Stopped
Mon Jul 23 2012 19:37:52 : File C:\Clientes\Videos\GFK\GFK_Posicionamento_19_23_07_2012_17_30.flv closed.
================== Encoding Statistics ====================
Current
Input Output
Time Bit Rate Drops fps Drops fps
Audio : 1:49:06 48 Kbps
Video 1: 1:49:06 172 Kbps 0 15.00 0 15.00
Average
Input Output
Video 1: 1:49:06 199 Kbps 0 15.00 0 15.00
<preset>
<name>Custom</name>
</preset>
<capture>
<video>
<size>
<width>320</width>
</size>
</video>
<audio>
</audio>
</capture>
<process>
<video>
</video>
</process>
<encode>
<video>
<advanced>
</advanced>
<autoadjust>
<dropframes>
</dropframes>
<degradequality>
</degradequality>
</autoadjust>
</video>
<audio>
</audio>
</encode>
<restartinterval>
<days></days>
<hours></hours>
<minutes></minutes>
</restartinterval>
<reconnectinterval>
<output>
<rtmp>
</rtmp>
<file>
<limitbysize>
<size>10</size>
</limitbysize>
<limitbyduration>
<hours>1</hours>
</limitbyduration>
<path>C:\Clientes\Videos\GFK\GFK_Posicionamento_19_23_07_2012_19_30.f lv</path>
</file>
</output>
<metadata>
<entry>
<key>author</key>
<value></value>
</entry>
<entry>
<value></value>
</entry>
<entry>
<value></value>
</entry>
<entry>
<key>keywords</key>
<value></value>
</entry>
<entry>
<key>rating</key>
<value></value>
</entry>
<entry>
<key>title</key>
<value></value>
</entry>
</metadata>
<preview>
<video>
<input>
<zoom>100%</zoom>
</input>
<output>
<zoom>100%</zoom>
</output>
</video>
<audio></audio>
</preview>
<log>
<level>100</level>
</log>
DumpGraph [03D59D20]
Filter [03D56B34] Output Video Renderer
Pin [03D56F0C] Input [Input] Connected to pin [02CF2EB8]
Filter [03D4CAEC] Input Video Renderer
Pin [03D4CEC4] Input [Input] Connected to pin [02CE62C8]
Filter [03DA2134] Meter Render Right
Pin [03DA250C] Input [Input] Connected to pin [02CDDBE8]
Filter [03D9E9BC] Meter Render
Pin [03D9ED94] Input [Input] Connected to pin [02CD3F20]
Filter [0974A008] Mux
Pin [0974A068] FLV4 [Input] Connected to pin [0C741E48]
Pin [0974A888] MP3 [Input] Connected to pin [0CA5E9B8]
Pin [0974AB00] out [ Output] This pin is not Connected
Filter [02CF2768] VP62_FL8 Compressor
Pin [02CF2788] Input [Input] Connected to pin [02CC8F88]
Pin [02CF2EB8] Preview [Output] Connected to pin [03D56F0C]
Pin [0C741E48] Output1 [Output] Connected to pin [0974A068]
Pin [0CA59A70] Output2 [ Output] This pin is not Connected
Filter [02CE61C0] Input RGB
Pin [02CE61D8] Input [Input] Connected to pin [03D9F7FC]
Pin [02CE62C8] Output [Output] Connected to pin [03D4CEC4]
Filter [0CA6BDB8] Audio Encoder Tee
Pin [0CA6BDC8] Input [Input] Connected to pin [0CC32D28]
Pin [0CA5E9B8] Output1 [Output] Connected to pin [0974A888]
Pin [0CA7A988] Output2 [ Output] This pin is not Connected
Filter [0CAD1788] Audio Monitor
Pin [0CAD1800] Input [Input] Connected to pin [03D59F54]
Pin [02CD3F20] Channel 0 [Output] Connected to pin [03D9ED94]
Pin [02CDDBE8] Channel 1 [Output] Connected to pin [03DA250C]
Filter [02CC8808] FPS Controller Encoder
Pin [02CC8818] Input [Input] Connected to pin [0CA692E0]
Pin [02CC8F88] Output [Output] Connected to pin [02CF2788]
Filter [0CC32820] Audio Encoder
Pin [0CC32828] PCM [Input] Connected to pin [03DA1E64]
Pin [0CC32D28] MP3 [Output] Connected to pin [0CA6BDC8]
Filter [0CA691D8] Resize
Pin [0CA691F0] Input [Input] Connected to pin [0CA315A0]
Pin [0CA692E0] Output [Output] Connected to pin [02CC8818]
Filter [0036F1A4] Audio Tee
Pin [0036F20C] Input [Input] Connected to pin [0CA20748]
Pin [03DA1E64] Output1 [Output] Connected to pin [0CC32828]
Pin [03D59F54] Output2 [Output] Connected to pin [0CAD1800]
Pin [0036FEDC] Output3 [ Output] This pin is not Connected
Filter [0CA30E20] FPS Controller Resize
Pin [0CA30E30] Input [Input] Connected to pin [03D1DB3C]
Pin [0CA315A0] Output [Output] Connected to pin [0CA691F0]
Filter [0CA20008] Audio Resampler
Pin [0CA20010] In [Input] Connected to pin [02CE8EC8]
Pin [0CA20748] PCM [Output] Connected to pin [0036F20C]
Filter [03D9FDB4] Video Tee
Pin [03D9FE1C] Input [Input] Connected to pin [03D9BCC4]
Pin [03D9F7FC] Output1 [Output] Connected to pin [02CE61D8]
Pin [03D1DB3C] Output2 [Output] Connected to pin [0CA30E30]
Pin [03D1DBFC] Output3 [ Output] This pin is not Connected
Filter [02CE87A0] Audio Filler
Pin [02CE87A8] In [Input] Connected to pin [03D53B44]
Pin [02CE8EC8] Output [Output] Connected to pin [0CA20010]
Filter [03D5C094] AUDIO SOURCE
Pin [03D53B44] Capture [Output] Connected to pin [02CE87A8]
Pin [00369EBC] Volume principal [ Input] This pin is not Connected
Filter [03DA18E4] SOURCE
Pin [03D9BCC4] Capturar [Output] Connected to pin [03D9FE1C]
Pin [00368FF4] Visualizar [ Output] This pin is not Connected
Pin [00369BF4] CC [ Output] This pin is not Connected
Pin [03DA1B9C] VBI [ Output] This pin is not Connected
Pin [0036FD04] Entrada de vídeo analógica [Input] Connected to pin [003692BC]
Filter [03D92BFC] Osprey-230 Crossbar 1
Pin [03D988DC] 0: Video Composite In [ Input] This pin is not Connected
Pin [03D98A44] 1: Video SVideo In [ Input] This pin is not Connected
Pin [003692BC] 0: Video Decoder Out [Output] Connected to pin [0036FD04]
Sample size 307200
Image size 307200
Planes 1
Colours used 0
Sample size 230400
Image size 230400
Planes 1
Colours used 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Image size 115200
Planes 1
Colours used 0
Sample size 0
wFormatTag 85
nChannels 2
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 307200
Image size 307200
Planes 1
Colours used 0
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 230400
Image size 230400
Planes 1
Colours used 0
Sample size 1
wFormatTag 85
nChannels 2
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 1
wFormatTag 85
nChannels 2
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Sample size 27648
96 x 96, 24 bpp c:0
Image size 27648
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 1
wFormatTag 85
nChannels 2
nBlockAlign 1
wBitsPerSample 0
cbSize 12
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 4
wFormatTag 1
nChannels 2
nBlockAlign 4
wBitsPerSample 16
cbSize 0
Sample size 115200
Image size 115200
Planes 1
Colours used 0
Sample size 1
Sample size 1
Mon Jul 23 2012 19:40:01 : Session Started
Mon Jul 23 2012 19:40:01 : Video Encoding Started
Mon Jul 23 2012 19:40:01 : Audio Encoding Started
Mon Jul 23 2012 22:00:00 : Audio Encoding Stopped
Mon Jul 23 2012 22:00:00 : Video Encoding Stopped
Mon Jul 23 2012 22:00:00 : Session Stopped
Mon Jul 23 2012 22:00:01 : File C:\Clientes\Videos\GFK\GFK_Posicionamento_19_23_07_2012_19_30.flv closed.
Current
Input Output
Audio : 1:23:05 48 Kbps
Video 1: 1:23:05 302 Kbps 0 15.00 0 15.00
Average
Input Output
Video 1: 1:23:05 200 Kbps 0 15.00 0 15.00
